View Poll Results: HEADS FOR THE 408
TFS
18
50.00%
AFR
14
38.89%
TEA STAGE 3 DARTS
4
11.11%
Voters: 36. You may not vote on this poll
wich heads for my 408??
Old Jan 13, 2007 | 07:55 PM
n20addict's Avatar
Default wich heads for my 408??
what heads sould i run on my 408? i want aftermarket heads because of the thick decks.which heads should i use tfs, afr, or tea stage 3 darts? this is a heavy nitrous motor and i plan on getting a custom cam from cam motion to match the setup.
Old Jan 13, 2007 | 08:01 PM
bad95killer's Avatar
Why i don't see ETP heads among them ?!
Anyway i'd go with TFS 240CC if the set available .
peace
Old Jan 13, 2007 | 08:08 PM
n20addict's Avatar
The reason for these heads is they are all in about the same price range and all have made decent power. havent really seen alot about ETP.
Old Jan 13, 2007 | 09:34 PM
BOWTIE's Avatar
Of those I would most likely choose the TFS's. However, I would most likely choose none of the above but instead go with the L92's, (granted that is a factory casting) or maybe check into some of the other head options using the LS7 style intake manifolds.
Old Jan 13, 2007 | 11:08 PM
n20addict's Avatar
i am afraid of p/v clearences with the l92 because of the size cam that im going to run.
Old Jan 14, 2007 | 12:20 AM
Asmodeus's Avatar
why not CNC'd LS7 heads?
Old Jan 14, 2007 | 01:06 AM
n20addict's Avatar
i believe a 4.030 bore is too small for the 2.20 valve in the ls7 head. not for sure though.
Old Jan 14, 2007 | 07:21 AM
darrensls1's Avatar
ETP makes a LS7 head for the 4.0 bore. Those are the heads I'm putting on my 408. They are expensive but when you factor in that the LS7 intake is far less expensive then the fast 90 (and flows better) then cost becomes compairable to other head/intake combos.
I did a lot of research and talked things over with Cary @ ETP as well as Mike @ New Era Performance. The general concensus was that we don't see any other heads/intake combo out performing the ETP LS7 heads and LS7 intake on a 408 setup.
Old Jan 14, 2007 | 09:19 AM
beardWS6's Avatar
ET 245`s here!
Old Jan 14, 2007 | 09:39 AM
n20addict's Avatar
Originally Posted by beardWS6
ET 245`s here!
what kind of power are you making with these?
Old Jan 14, 2007 | 12:50 PM
beardWS6's Avatar
Will be able to tell you more in 2 weeks. My motor will be completed then. Before she blew I was having some problems. I will let you know soon!
Old Jan 15, 2007 | 10:45 AM
ATVracr's Avatar
ET 225's on my 370
made 475 on motor ... nitrous motor , Mustang dyno
750 on the spray
Old Jan 15, 2007 | 11:56 AM
beardWS6's Avatar
How big a shot you doing to get 750?
Old Jan 15, 2007 | 12:00 PM
JL ws-6's Avatar
Race your car!
et 240's on my 402.. couldn't be happier. Track times in sig, car's still spinning alot too.
Old Jan 15, 2007 | 12:27 PM
ATVracr's Avatar
2 stage ... 125 on each
Lookin to make at least another 100+ with my new intake and direct port.
Old Jan 15, 2007 | 01:41 PM
Sick setup man
peace
Old Jan 15, 2007 | 05:11 PM
Brian Tooley Racing's Avatar
If the combo was N/A, turbo or supercharged I would say TFS...since it is heavy nitrous you need intake port volume and a nasty exhaust port....flip a coin.
Better yet, maybe someday we will get the TFS 240 finished and it will be a no brainer.
Old Jan 15, 2007 | 05:41 PM
n20addict's Avatar
well it looks like most people are going with the tfs heads. i wish they would hurry up with the 240's i am ready for the heads now.
Old Jan 15, 2007 | 10:41 PM
PowerShift408's Avatar
I know I'm going with Brian's stage 3 241 or 243 casting heads.
Old Jan 17, 2007 | 10:02 AM
ATVracr's Avatar
Originally Posted by bad95killer
Sick setup man
peace
Thanks !
