How do I know if my valvespring is broken?
If you can get an Auto-tap, you should be able to see misfires on the cylinder with the broken spring.
Even if the spring looks good, see if you can twist the spring around underneath the rocker arm. If you can, its bad. His springs looked good at first, but in the minimal light available its hard to tell unless there are pieces laying in the valley.
You should be able to reuse your valve cover gaskets.
Just some thoughts,
Denzil
If the car is running like crap at idle, then generally, if it's due to a broken valve spring, then it will be broken enough to see it. It runs like crap because the valve is not closing all the way due to the reduced height of the broken spring.
