MMS 229 v2.1 is in
Old Mar 16, 2002 | 08:18 PM
Fireball's Avatar
Default MMS 229 v2.1 is in
well haven't really "tested" it yet but so far so good. Found idle immediately with the factory 800 rpm idle speed. No surging or anything whatsoever. Its definatley choppy but nothing that I'd consider severe haha. Might lower the idle speed some just to see what I can do for idling <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
There is a definate loss in torque below 3500 rpm but in the low gears that is counteracted with my mechanical torque (BIG GEARS)
LS1edit is due to arrive tuesday sometime, I'll spend some time wednesday playing with it some <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I'll keep you all informed on track times (hope to go next weekend <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )
Old Mar 16, 2002 | 09:15 PM
Raughammer's Avatar
D(irecto)r Pepper
Default Re: MMS 229 v2.1 is in
Killer... now after the edit... GO TO THE TRACK! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Keep us informed bud.
Old Mar 16, 2002 | 09:29 PM
VINCE's Avatar
Shorty Director
You guys are going all out.. This is going to be a crazy year..
Old Mar 17, 2002 | 09:39 AM
Ragtop 99's Avatar
Have you done some ATAP runs to see how far off you are?
Is the idle significantly worse than you B1 or just a bit rougher?
Old Mar 17, 2002 | 09:45 AM
Fireball's Avatar
Its not that I don't think its far off, its that I don't have the limiter for this cam yet. I'm still stuck at 6600 rpm from HPP3. This cam don't really peak until 6800.
As for idle...its quite a bit choppier than the B1 but its definately not as choppy as Scotts (V2.0)
Old Mar 17, 2002 | 10:09 AM
ONYXSS's Avatar
Brian, are you sure about that? Peaks at 6800??
That would have you shifting over 7000 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 17, 2002 | 10:46 AM
Fireball's Avatar
yeah...according to mike morgans dyno he posted for a cam only 229, it peaked about 6800.
I'm planning on 6800 shifts right now until my new motor is ready <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 17, 2002 | 10:56 AM
TimZ28's Avatar
What is the advertised duration and intake centerline?
Old Mar 17, 2002 | 01:03 PM
Fireball's Avatar
bastard. haha...I'll get on that <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
until then I'll do what I do in HPP3....short tire + 4.56
Old Mar 17, 2002 | 01:07 PM
Fireball's Avatar
well...didn't have a vacuum gage handy before the swap so I went ahead and got the MAP and Barometric readings from Atap for the 229
vacuum: 30.2 (barometric) - 15.9 (MAP) = 14.3 inHg
IAC pintle: 79-81
idle speed: 773-832 rpm
Old Mar 17, 2002 | 05:09 PM
TimZ28's Avatar
I can see that cam holding to the high 6k range but I don't see you peaking at 6800 with a cam only setup. Would love to see some dyno graphs when you get it all worked out.
Tim
Old Mar 17, 2002 | 05:15 PM
Jason99T/A's Avatar
I can shift faster than you.
Fireball, I would be curious to see your dyno results. What valvesprings are you using? Let us know when you get some track times. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 17, 2002 | 05:25 PM
Fireball's Avatar
running isky double springs (MTI double spring package)
Old Mar 17, 2002 | 07:01 PM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TimZ28:
<strong>I can see that cam holding to the high 6k range but I don't see you peaking at 6800 with a cam only setup. Would love to see some dyno graphs when you get it all worked out.
Tim</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I just looked at dyno and it peaked at 6200 and maintained peak to 6400, this cam shouldnt need more than 6800 shifts, IMo. At 6900 motor lost 20 hp, peak torque is at 4800, this is a pretty common power band and shouldnt really be that hard to utilize.
Old Mar 17, 2002 | 07:04 PM
LS1derfull's Avatar
Tim</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I just looked at dyno and it peaked at 6200 and maintained peak to 6400, this cam shouldnt need more than 6800 shifts, IMo. At 6900 motor lost 20 hp, peak torque is at 4800, this is a pretty common power band and shouldnt really be that hard to utilize. This was with no cats also so i think that would raise peak slightly also.
Old Mar 18, 2002 | 12:14 AM
Fireball's Avatar
duration at .006: 281
C/L: 111
duration at .050: 230
Old Mar 18, 2002 | 12:26 AM
John B's Avatar
Moderator
Fireball, you're going to be disappointed when you learn that LS1_Edit only takes gear ratio's up to 4.56! Better have Ken make a software revision for you <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 18, 2002 | 07:01 AM
Fireball's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1derfull:
<strong>[QUOTE]I just looked at dyno and it peaked at 6200 and maintained peak to 6400, this cam shouldnt need more than 6800 shifts, IMo. At 6900 motor lost 20 hp, peak torque is at 4800, this is a pretty common power band and shouldnt really be that hard to utilize. This was with no cats also so i think that would raise peak slightly also.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">well, that graph really looks like it peaks around 6250 but holds essentially a flat line from 6250 to 6750 rpm. then it falls. This is why I was saying peak at 6800. My plan is to set my shift light to 6800 and I usually nail it within 100 rpm to my shiftlite. so 6800-6900 shifts should work.
Old Mar 18, 2002 | 01:19 PM
Fireball's Avatar
thats why I did this...its not what everyone else has done. dyno testing will let me know where it peaks <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 18, 2002 | 02:13 PM
Jason99T/A's Avatar
Brian, when do you plan on dynoing?
