What are teh stock cam specs for the different year LS1s?
Just curious about them. I was bored and mic'ed a stock 02 LS1, multiplied what I got by 1.7 rockers and came up with .469 lift... seems kinda low. I beleive the base circle was 1.55 inches. Does anyone have the exact specs on the different year LS1s?
Re: What are teh stock cam specs for the different year LS1s?
specs on my 98 stock cam are-
270/272 at .006" tappet lift
199/208 at .050" tappet lift
LSA is 119.5 degrees and it appears Gm ground 3 degrees retard in the cam as it installs at 122.5 dot to dot.
Lift is right near or ever so slightly less than .500" at the valve.
There is a lot of false info out there on the stock 98 cams.I see it all the time.
This is correct and was very carefully measured.
I have no info on the later year ls1 f-body cams though.
Steve
Steve
1997-00 LS1 C5 (intake/exhaust) 202/210; .472/.479; LSA: 117 Base circle: 19.7mm
2001-02 LS1 C5 198/208 ; .500/.500; LSA:115.5 Base circle: 19.7mm
2001 LS6 C5 Cam: 204/211; .525/.525 ;CL:118/114; LSA:116.0; Base Circle: 19.3mm (-0.0158")
2002 LS6 C5 Cam: 204/218; .551/.547; CL:120/115; LSA:117.5; Base Circle: 19.0mm (-0.0276")
Chevy Hot Cam 218/227; .525/.525; LSA: 112
My 98 stock cam Base circle measured 1.552. My heel to Nose measured 1.843. This is a difference of .291 x 1.70 rocker ratio yields a valve lift of .4947.
I then measured my 01 L06 cam and it measures 1.520 and 1.826, respectively. This gives a cam lift of .306 x 1.70 = .5202 valve lift.
Larry,
Not to be to nitpicky, but stock rockers are actually a 1.71 ratio and not 1.70 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .
My stock cam measures in at .498-.499"
If I use your lobe lift of .291", it works out very close to the actual measurments on my motor.
Steve
Steve
