Decided my cam parameters, now help me decide
best E.T. possible
badass idle and sound (112 LSA and split duration)
make peak power around 6600
work with stock heads
high end power is more important than low end
So, does anybody know what type of cam will suit me nicely? I want one that gives me a great E.T. and sound like a older musclecar. My car:
3.73s or 4.10s (depends on the cam), 3600 lbs, 4400 stall going in soon
Thanks a lot for any suggestions and info on where to buy them.
But working within your cretiria, I would suggest the Comp XE-R lobes in a
intk 222 .581 (lobe #3721)
exst 226 .585 (lobe #3723)
on a 112 l/s with 4 degrees of advance ground in.
There are two camps on the single vs. dual pattern cam. I am more of a fan of the single pattern myself. I just have not seen the proof yet that the duals make more power in an NA application. But I don't want to stray your thread. Good luck with your choice and enjoy!
Mark
BTW, Raughammer, your website is awesome. It has helped me a lot as far as information and just entertainment. That is a beast of a car you have there.
<strong>Well,
You want crazy idle with topend power?? I have to warn you, it will have a very crazy idle.
This cam operates in the 4000-7000 range and has a pretty narrow power band.
The specs are 235/235 .589"/.589" lift 110 LSA
You will need the 4400 stall. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Damn Mike!! Any track times/dyno results with this cam? That has to be nasty in a 346ci car. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>You want crazy idle with topend power?? I have to warn you, it will have a very crazy idle.
You will need the 4400 stall. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Wow, those specs definately look like it would have an awesome idle. What kind of E.T. gain would you expect to see on a stock headed car? Any dyno #s? About where would the shift points need to be? If the cam is that awesome, I might have to look into building up my bottom end so that I could run it. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> But, if you guys think that this cam will be all sound and little go, then I would rather have performance than sound.
<small>[ March 18, 2002, 04:05 PM: Message edited by: quickWS6 ]</small>
I get the impression the biggest factor you are considering in your cam selection is mainly a rough lopey idle.
Do you have headers? Just my opinion, but on a [stock headed] car with very minimal mods, your cam selection is wrong. You just cant slap in the biggest cam you can find in a basically bone stock engine and expect anything more than poor drivability (ie: poor throttle response, loss in low RPM torque, and unacceptable idle).
Well, you wont be the first person ever to overcam a stock motor. Back in the old days, many folks would also over-carb there cars too. Just find the biggest Holley double pumper carb that money could buy and put it on a stock motor and wonder where all the power went....
Not trying to preach to you, but, a rough, surging irratic idle with continual SES lights should not be a priority.
Just my opinion
Good Luck....
<small>[ March 18, 2002, 08:19 PM: Message edited by: Kimchee and Rice ]</small>
Also, I know what you are talking about overcarbing and overcamming. There is a 302 Z28 that a good friend of mine has with dual Holley 650s and a .600"+ lift cam. It does sound absolutely wonderful though. It runs dang nice, too. But I haven't been able to line up with him yet. So, I can see myself enjoying having a car that performs better but sounds like it shouldn't. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Help me go like this----> <img border="0" alt="[Pontiac]" title="" src="graemlins/formula.gif" />
That cam? Heck no. That is WAY to big for your application in my opinion.
One of your criteria was MAX E.T., Ask your self who is running "hella-fast" with that Cam? I am not saying it is a bad cam. But with your set up, I would not recommend it.
My advice? Keep looking. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Campbell
Split duration with stock heads isn't a bad thing. The add exhaust duration may not add to the peak power very much but it will certainly help extend the powerband. I would also pay very close attention to where the "installed" intake centerline is. 4 degrees of advance will defintely take away from the upper end. Straight-up may very likely make more power in the upper end.
QuickWS6... I'm also going with stock heads. For what it is worth I just received my XE-R grind. I went 224/228 112 110 0.581 0.588. I will be installing it on a 112 IC. I know some guys aren't into sims very much but I am and the simulator has always been very close on any combo I've ever compared against actual (assuming you give it accurate data). I spent alot of time simulating before I decided on the specs for the cam. The two graphs represent the same setup but with different lobe profiling (solid vs. roller). I would say the XE-R lobes will fall somewhere in between when it comes to actual. These sims were done with stock flow #s with the LS1 intake accounted for.
<img src="http://home.mpinet.net/trs/XE-R_224_228_SIM.gif" alt="" />
Tim
<small>[ March 18, 2002, 12:44 PM: Message edited by: TimZ28 ]</small>
jeeeez thats a studly cam. (too much for me!)
JC
OnyxSS was running over 123+ mph with this cam, OnyxSS raceweight is approx 3500pounds as well. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I am running this cam and LOVE it!
Another thing to note is that I am running it on stock tuning for now. Working great so far and the power difference is very noticeable over the B1 I was running earlier. (I did change heads at the same time however)
Hope this helps,
Chris
Couple that with some good stage 2 heads and you will have a very good performing set up.
For example, the MTI Hammer or C2 cam and MTI stage 2 heads would be a good combo. It works for me. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Good luck.
Lopes really good.
Choosing the right Heads/Cam pkg. can take a long time, so take your time. You'll find something you like.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
