spring specs
Old Jan 15, 2007 | 03:24 PM
Juiced's Avatar
Default spring specs
Crane 99876
Outer Diameter 1.565
Inner Diameter 1 1.146
Inner Diameter 2 0.740
Seat Pressure @ Installed Height 190 lbs @ 1.950
Open Pressure and Height 552 lbs @ 1.250
Coil Bind 1.200
Average Spring Rate 504 lbs/in
How would these do with a .750 lift cam?
Old Jan 15, 2007 | 05:24 PM
Old SStroker's Avatar
Originally Posted by Juiced
Crane 99876
Coil Bind 1.200
Not so well if you installed them @ 1.950 (190#). They'd be in coil bind at .750 valve lift.
You need to choose a spring that will control the valve at the llift and rpm you plan to use. The spring requirements depend on that, plus lobe profile, valvetrain weights and stiffness, vehicle application, among other things. Your whole valvetrain needs to be looked at by your cam designer. While he may choose a spring that gets to within .050-.070 of coil bind, he won't choose one that gets into coil bind by design.
.750 is serious lift, and if you are planning serious revs, please get professional help choosing all of your valvetrain parts.
Old Jan 15, 2007 | 08:00 PM
Juiced's Avatar
I just have the springs laying around and wanted to know if they would be of any use.....
