should I get it?
Old Jan 15, 2007 | 04:45 PM
Rallycourt's Avatar
Default should I get it?
my friend wants to sell me his cam that he had in his 402 vett. I'm not sure on how it will work in my car seems how its just a stock motor with most boltons. he says it should work fine and make good power. here is what it is. 236/236 .585 .585 @ 112lsa
Can anyone tell me if you have ran a cam like this and what kind of setup you had. And maybe some HP/Tq #'s I will be close to.
I but down 321rwhp and 331rwtq with intake, free mods, headers, catback, 410's
Old Jan 16, 2007 | 12:28 AM
Rallycourt's Avatar
no one has a cam like this? Is this a bad choice? need some newbie help here please.
Old Jan 16, 2007 | 12:33 AM
00454sscamaro's Avatar
looks like a cam right in between mild and wild.. read other post's with lots of replys it will give you a good bit of info about cam specs.or use the search button.
Old Jan 16, 2007 | 01:03 AM
ChaseSS's Avatar
how many miles on the cam? the cam itself isn't that expensive to buy new
Old Jan 16, 2007 | 01:36 AM
Rallycourt's Avatar
he wants $250 for it. less than a 1000K on it. he drove the car from Tx. to Az. and back to Tx for a different cam. I want to make good power and I want it to sound good but still be able to drive it on the street. It's not a daily driver so it's ok if it's a little wild.
Old Jan 16, 2007 | 07:15 AM
brad8266's Avatar
That cam will gain you a lot of power mid range and up top but will kill low end due to the large intake duration.
Old Jan 16, 2007 | 03:49 PM
GuitsBoy's Avatar
Yeah, you probably will lose a bit low end. Its not very high in terms of lift. I bet its on some lazy lobes. For the extra hundred bucks, id go get a proven performer. Some snappier lobes and a little bit of split will help liven it up down low. Its not like hes making you an offer you cant refuse.
Old Jan 17, 2007 | 01:47 AM
Rallycourt's Avatar
thanks for the pointers guys. This is going to bed my first cam. I'm still trying to learn what all these numbers translate into as far as how the motor is going to preform. sounds like it should be a pretty good cam. I want to leave a little room to upgrade went I get used to this power I can get the fast feeling all over again! I don't mind a little low end loss. No one races from a dig around here anyway.
