Need help ASAP in choosing what pushrod for XE Cam.
Old Mar 21, 2002 | 01:13 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Need help ASAP in choosing what pushrod for XE Cam.
What do the GTP guys use?
Typically less preload is better than more, but we're not talking about a big difference.
Old Mar 21, 2002 | 01:18 PM
Magnus's Avatar
LS1TECH Sponsor
Hmm... not sure..
In the future I might go with a higher lift cam...
I MIGHT mill the heads again but I'm not really looking forward to pulling them off again. Cam is easy, heads are not.
Old Mar 22, 2002 | 12:32 AM
Magnus's Avatar
LS1TECH Sponsor
Default Need help ASAP in choosing what pushrod for XE Cam.
Hi,
Application is a 3.8 V6.. but still comparable.
Stock cam base circle: 1.237
Stock pushrod length: 7.025 (3 piece 3/8")
COMP Cam XE base circle: 1.190
Heads have been milled .020"
So basically I need a pushrod 7.0285 in length.
I'm looking at http://www.compcams.com/catalog/ and they have many types of pushrods to choose from. I know I want chromoly 5/16" with a 210* tip. But what rod type do I go with.?
I plan to stop by E&R this afternoon and order them for tommorow.
Thanks.
<small>[ March 21, 2002, 12:34 PM: Message edited by: Magnus ]</small>
Old Mar 22, 2002 | 12:42 AM
Magnus's Avatar
LS1TECH Sponsor
Hmm... I can only find a rod from this page:
http://www.compcams.com/catalog/274.html
that matches.. it is 5/16" which is good.. chromoly good..
It has a rounded tip.. I think that should be good for .520" lift for now..
what do you guys think? I need 7.0285 but can shoose from 7.00 or 7.05.. so which do I choose?
<small>[ March 21, 2002, 12:50 PM: Message edited by: Magnus ]</small>
