IAC count after H/C install
Cam is the 226 234 cam... The question is where is my IAC count supposed to be. When i was looking at it on my scanmaster the other day it was in the 60's
its still at the shop cause the L-terms are way off from on bank to another..
sigh
Did you open up the TB hole yet?
BTW, what was the problem before? Never heard, or i missed it.
Call me fool, you never did <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
<strong>yeah i have the TB drilled Matt..
the problem before was the valve covers hitting the springs.. i was never told we needed to cleanence the covers on a 98</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmmm. Well I hope either you were lucky, or my friend was very unlucky. He had the same problem, but it ended up far worse than just a high iac count.
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PhantomTA:
the problem before was the valve covers hitting the springs.. i was never told we needed to cleanence the covers on a 98</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmmm. Well I hope either you were lucky, or my friend was very unlucky. He had the same problem, but it ended up far worse than just a high iac count.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Bent valves?
<small>[ March 21, 2002, 08:44 PM: Message edited by: PhantomTA ]</small>
At 60, I'd give it a day or two of road work, then think about another 1/64" drill out if the idle is taking a dive when breaking in city traffic.
What's your TB hole size drilled to now?
Rick
I cant afford another rebuild <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I put the idle set screw higher to get TPS to .52 volts, now the IAC is 10 and dives to 1, then surges back up to 10, and repeats over and over.
TPP on scanmaster is ALWAYS zero. Is that pintle position?
what's your throttle blade drilled to now?
