Found The Right Cam For Sure! I AM DONE!!
Old Jan 17, 2007 | 07:26 PM
brad8266's Avatar
Originally Posted by TORCHD 02 TA
with the DCR calc.. can you input the thickness of that gasket so that i can see the 8.38 DCR????
yes..
Old Jan 17, 2007 | 07:30 PM
TORCHD 02 TA's Avatar
Originally Posted by brad8266
yes..
LOL yea i jsut figured that you can edit the green... sorry!
Old Jan 17, 2007 | 07:36 PM
brad8266's Avatar
lol, yeah you can edit all of that in green.
Old Jan 17, 2007 | 11:38 PM
well back up to the top for others to see...
Old Jan 18, 2007 | 09:45 AM
N4cer's Avatar
Well, not sure where you got that Motive gears whine, but my Motive 4.10 is dead silent. It just has to be installed properly. Richmond is the gear set that is commonly accepted to be the worst made.
If you're changing to a thinner head gasket, you might as well mill the heads as well. No reason to leave it at a low DCR when you could bump it up to 8.5+. It's not hurting me at all to be at 8.6-8.8. Long story, but basically I asked the shop to mill .030" off the heads, but when I got them to the garage my tuner measured the deck thickness and said he thought they had .040" milled, but we were in the middle of stuff and I don't remember the measurements now.
I still say that's a great cam choice, but I'd have done it on LSK lobes instead of XE-R. But to each his own. It should still be awesome for your goals. And I only say that because it's between my disappointing 224 baby cam and my very enjoyable G5X3. Sounds like an excellent compromise.
Old Jan 18, 2007 | 04:50 PM
Just outta curisoty.. why would you put it in LSK and not the XE-R?? All the numbers are EXACTLY the same.. Nothing changes.. I will just have a more aggressive lift that is all. As far as HP goes what is the difference < 10???
Old Jan 18, 2007 | 05:07 PM
brad8266's Avatar
With the same durations on an LSK lobe, the lift will be higher and the lift will come on faster. The result is more air entering the chamber and more air leaving the chamber for the given duration.
Old Jan 18, 2007 | 05:09 PM
ahh i see.. but it wont be to noticable as far as power, will it? makes sense that they are at a faser ramp rate.. more air in/out
Old Jan 18, 2007 | 05:15 PM
brad8266's Avatar
Maybe not that drastic of a difference, but I would guess there would be some overall gain throughout the entire rpm range. I cant really say though since I never ran an LSK cam. Pat G could probably tell ya, he uses LSK's.
Old Jan 18, 2007 | 05:35 PM
N4cer's Avatar
My understanding is that it would give more power throughout the rev range. That way you'll make up a little for the small cam. I think that cam is a wonderful grind in either LSK or XE-R, but I still consider it small. I see the LSK lobes making up for the sacrifice. Not to mention, you'd have something really cool that others don't have.
And 10hp is 10hp. Sure, a good driver vs. an okay driver is worth over 50hp (I'm usually the less talented driver), but it would suck to make 441hp instead of 451. Not that those high numbers are to be expected. But you see the point.
Look at the difference between XE lobes and XE-R lobes. Nobody runs XE lobes anymore, and there's a reason for that.
Old Jan 18, 2007 | 06:00 PM
Originally Posted by thehammer69
The numbers may be the same a .006" and ,050" lift, but once you go beyond .050" of lift, the duration of the LSK lobes get noticably larger than the XER lobes. Also the higher total lift takes advantage of a heads maximum flow numbers.
Hammer
yea i see what you are saying.. hmm that is worth thiking about. Remeber i am staying ON STOCK NON P&P HEADS!!!
Old Jan 18, 2007 | 06:04 PM
  #32
if i do the 228/232 on a 110+2 the DCR is 8.15 and with .040" gaskets it gets it to 8.38.. That is now bad....
if i do the 228/232 on a 110+4 the DCR is 8.28 and with .040" gaskets it gets it to 8.51.. Now that is way better.
But going from a +2 grind to a +4 i will loose some TQ. But will the higher DCR make up for it
EDIT: I am jsut playing with some numbers
Old Jan 18, 2007 | 06:05 PM
  #33
thehammer69's Avatar
Hammer
Old Jan 18, 2007 | 06:20 PM
  #34
what is every one and their DOUBLE POSTS???? LOL
Old Jan 18, 2007 | 08:03 PM
  #35
Wasn't on purpose...website appeared to have gone astray, and I kept trying to push a post through. I gave up and then now I see it went through twice. I have now deleted one.
Hammer
Old Jan 18, 2007 | 08:05 PM
  #36
Why do you think you will loss torque going from +2 to +4?
Hammer
Old Jan 18, 2007 | 08:17 PM
  #37
N4cer's Avatar
Yeah, not sure why you'd lose torque. But I've never messed with specs for a small-ish cam before. I'm very interested in this though.
I guess my thoughts are that if you're removing heads to use a thinner gasket, why not put some love to the heads while they're off?
Old Jan 18, 2007 | 08:54 PM
  #38
brad8266's Avatar
You will gain tourqe by going from a +2 to +4 advance due to the increase of DCR by closing the intake valve earlier. You will gain down low at the expense of power up top.
Old Jan 18, 2007 | 08:55 PM
  #39
All are @ .050
XE-R 110+2
IVO - 6
IVC - 42
EVO - 48
EVC - 4
ECL - 112
Overlap - 10
DCR - 8.15
XE-R 110+4
IVO - 8
IVC - 40
EVO - 50
EVC - 2
ECL - 114
Overlap - 10
DCR - 8.28
LSK 110+2
IVO - 6
IVC - 42
EVO - 48
EVC - 4
ECL - 112
Overlap - 10
DCR - 8.15
LSK 110+4
IVO - 8
IVC - 40
EVO - 50
EVC - 2
ECL - 114
Overlap - 10
DCR - 8.28
So what gives a better all around performance?
Old Jan 18, 2007 | 09:06 PM
  #40
brad8266's Avatar
All are @ .050
They are all biased to the intake side so they are all more suited for low end power. If you want some more upper end power, lose the advance on the cam to bring overlap closer to TDC. if you are looking for the most power with the highest DCR and dont mind giving up some high end power, go with the +4 LSK lobes.
really though all these cams will do well for what it seems like you are looking for: low end street drivability with the ability to compete in the ocassional street race.
