***heads/cam install finsished, go and pick up my car now***
Old 03-26-2002, 08:27 AM
Austrian Vette's Avatar
Default ***heads/cam install finsished, go and pick up my car now***
You remember my post searching for help??
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=1;t=003806
Now after huge additional costs (for searching the error and another camswap)
my heads/cam /LS6 intake / underdrive pulleys / Ford #30 Injectors install is finished and the car is running.
It turned out that the cam was 180° ground off.
We were ready to drive when we recognised that the engine fired 180° off, so we had to do that work all over again.
We got the cam yesterday and started the install.
I just got a call from my mechanic (I had to work today so couldn´t help him finish), that the car is running. He revved the engine and it holds the idle.
So I may not the need the idle relearn procedure (but I think I´ll do it anyway).
In an hour a friend of mine picks me up and brings me the 100 miles to my mechanic (he only does an engine and tranny oil change and then the car is ready).
I will hook up the AUTOTAP and watch my A/F meter on my way back home as I wanna check if timing and A/F is ready for the NOS.
I don´t have much time as first race is April 7th and I plan to spray me into the 9`s (as safe as possible).
Can´t wait to feel how the car runs now......and sounds.
I´ll keep ya all updated!!!
BTW, thanks to all of you for your intrest and for your help!!!
You all are
I´m sad that you all are so far away, or I would give a party!!!!
So all I can do is saying
THANK YOU
THANK YOU
THANK YOU
THANK YOU
THANK YOU !!!!!!!!!!!!!!!!!!!!!!
Now I hope all is OK on my way home!!
I´ll let ya all know!!
Michael
<small>[ March 26, 2002, 08:28 AM: Message edited by: Austrian Vette ]</small>
Old 03-26-2002, 04:13 PM
Default Re: ***heads/cam install finsished, go and pick up my car now***
Car is at home!!
Spins tires at WOT after downshifting at 70mph.
Love that.
It pulls and pulls....
And it sounds great.
But, I have three problems:
1) The valvetrain is loud (may be normal, but it`s louder than stock)
2) The car runs rich (should be under control with the MAFT, soon)
3) The car doesn´t shift in 4th when on WOT?!?!?
(Can it be the program on the new PCM that I got with an
custom programming) Hope that is it.
Any thoughts on that are welcome!!
Michael
<small>[ March 26, 2002, 04:58 PM: Message edited by: Austrian Vette ]</small>
Old 03-26-2002, 04:27 PM
Holes02's Avatar
The extra valvetrain noise is normal.
The rich running you can fix with the MAFT.
Your car is an A4 I assume?
If so, then it may be the programming.
Give the company that programmed it a call and see what they say.
Old 03-26-2002, 04:39 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Holes02:
<strong>The extra valvetrain noise is normal.
Give the company that programmed it a call and see what they say.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">HolesO2,
thanks!
I´m bit nervous because of the troubles I had with the cam, so I´m happy to hear that the louder valve train noise is normal.
Yes, it´s an A4, I´ll give the programmer a call.
Michael
