A good cam for mid to high end power?
Old Mar 27, 2002 | 01:37 PM
FormulaWS6's Avatar
Default A good cam for mid to high end power?
Idle is a concern for me, so i do not want something to big. I am not planning on getting any tuning right now either.
the Comp 216/220 seems to make good power at the higher end & has good dyno numbers.
I have a ST3500 and A4. Thanks..
Any other good higher RPM power'd cams?
Old Mar 27, 2002 | 03:10 PM
Sparky's Avatar
Default Re: A good cam for mid to high end power?
B1 might do you good. 221 558 114.
With it (and LS6 intake) I picked up .5 sec.
Old Mar 30, 2002 | 12:29 AM
Ragtop 99's Avatar
to keep idle good quality use a 114 or 115 LSA with that cam. The lower your planned idle speed, the more you should consider the 115 LSA.
Old Mar 30, 2002 | 12:42 AM
Terry Burger's Avatar
I make great power from 4000-7000rpm with my cam.
