Increased intake duration vs exhaust?
If you have a GREAT exhaust setup. 1 3/4 or 1 7/8 long tubes, dual 3 inch with Xpipe and bullets for example, your exhaust side is not really that restricted provided head flow numbers on the exhaust look good. If you went with a bias towards intake duration I wonder how it would work out?
Say a 228/224 XE-R .588/.585 based cam on a 112 Lobe seperation?
Or a 228/226 based cam?
Anyone attempt this or know of anyone that has tested with it?
We all know with a restrictive exhaust system more exhaust duration helps rid the exhaust charge and pull in a fresh intake charge. But with a very free flowing exhaust system your duration requirement on the exhaust will be lower than that of a restrictive setup.
Why isnt the opposite case true considering our restrictive intakes?
Thanks fellas,
Chris
<small>[ March 28, 2002, 10:14 AM: Message edited by: Chris ARE 360 ]</small>
- Mitch R.
Current thinking tells us that as the durations increase the engine has to spin faster and faster to make power, and the idle rpms have to be raised more and more. This is because of the overlap associated with big duration cams. If you lower the exhaust duration overlap is reduced, and more intake duration can be added. Then the rev limiter and idle can remain within decent limits. Which leads me to my third point...
With the decreased overlap, less compression would bleed off in the lower rpms thus increasing low end torque (or at least keep from losing low end torque) while still increasing upper rpm hp because of the greater intake durations.
Just my .02
'Los <img border="0" alt="[Chevrolet]" title="" src="graemlins/camaro.gif" />
<small>[ March 29, 2002, 10:46 AM: Message edited by: Carlitos ]</small>
<strong>With the decreased overlap, less compression would bleed off in the lower rpms thus increasing low end torque (or at least keep from losing low end torque) while still increasing upper rpm hp because of the greater intake durations.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Overlap and compression "bleed-off" are 2 different events and are not related. Overlap is determined by the exhaust closing and intake opening event. Dynamic compression is determined primarily by the intake valve closing event.
Chris
<strong>[QUOTE]Overlap and compression "bleed-off" are 2 different events and are not related. Overlap is determined by the exhaust closing and intake opening event. Dynamic compression is determined primarily by the intake valve closing event.
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Oops! Yeah, you're right. Just got off a 24 hr shift when I added that. Hadn't had my nap, yet. <img border="0" alt="[boring]" title="" src="graemlins/gr_zzz.gif" /> I was confused a bit. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I was probably thinking of bleeding off intake charge in FI applications with tight LSAs. Muh bad. I'm not even sure if that sounds right, right now. I just woke up. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
'Los
