Any HP difference between stock...
Old Mar 30, 2002 | 11:59 PM
WEASEL's Avatar
Default Any HP difference between stock...
Between stock 99 heads and stock 6.0 heads?
I'm looking at the 224/228/114 cam with the 918 springs in prep for an ATI stage II.
Just wondering as a baseline if I should put some stock 6.0 heads on at the same time I do the cam.
Any ideas on HP gains with the cam, stock 5.7/6.0 heads, and a holley intake with the usual bolt ons.
Old Mar 31, 2002 | 12:32 AM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Any HP difference between stock...
If you bolt on the 6.0l heads as is, your compression will drop from 10.1:1 to about 9.6:1. This is because the 6.0l head has a larger combustion chamber to match with the 6.0l truck's 4.00" bore.
The 6.0l heads are a good starting point if you would like to get them ported. However, I think you would actually loose power by just bolting them on as is. Get them ported and have them milled at least 30-40 thousandths to get the compression in the 10.7:1 range.
Jason
Old Mar 31, 2002 | 12:34 AM
Jason99T/A's Avatar
edit: I just noticed you were planning on installing a ATI blower. You might reconsider milling them then. Maybe just a clean-up pass on them.
Old Mar 31, 2002 | 01:18 PM
WEASEL's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jason99T/A:
<strong>edit: I just noticed you were planning on installing a ATI blower. You might reconsider milling them then. Maybe just a clean-up pass on them.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmmm.....how about gains with just the cam? Loss with the heads, maybe 10-15?
Any ideas?
