Cam with Stock heads
Old Mar 31, 2002 | 11:03 PM
01SStud's Avatar
Default Cam with Stock heads
I wanted to hear what you guys think about this. My car is a M6. Would a C1 or a 224/224 .581 .581
Comp Cam work w/ stock heads. If so which one would you guys run, I am wanting basically the biggest cam i can run with stock heads, so if you guys have any other suggestions would you mention them. Is the T1 a pretty good choice as well, if i cant run the C1.
THanks,
Chris
Old Mar 31, 2002 | 11:24 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Cam with Stock heads
I have been very happy with my Thunder 224 114lsa cam. Drives great and makes awesome power! Either of the cams you listed above would work well also. Good luck!
Old Mar 31, 2002 | 11:25 PM
RyanJ's Avatar
SSU Moderator
i think you should run the ABC123. its the BEST for stock heads. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
just kidding of course.
<small>[ March 31, 2002, 11:25 PM: Message edited by: DB Cooper ]</small>
Old Mar 31, 2002 | 11:46 PM
VINCE's Avatar
Shorty Director
All the cams you mentioned will work fine with stock heads..
Old Apr 1, 2002 | 06:19 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'm getting ready to swap cams for the XE-R 224/.581" that you mentioned on a 112 LSA. Another board member made the same swap a few weeks ago while keeping his stock heads, and he picked up 37 RWHP.
__________________
