Verify my pushrod calculation please
Stock cam base circle- 1.553
New cam base circle- 1.450
Stock pushrod length- 7.400
Length needed = ((stock base-new base)/2) + stock pushrod length =
((1.553-1.450)/2) + 7.4 = 7.452 for new rod length.
Your calculation is correct but stock p-rod length is not 7.400
since average stock preload is in the .100 neighbourhood and 7.450 would put you over that, the next best choice is 7.425's
So 7.39 stock + .0515(base difference) - .018(difference between stock and new head gasket) - .030 (head mill) = 7.3935
The 706 5.3L cast heads unmilled do keep the same height as LS1 heads right?
And with all the variances you're playing with better get a push rod length measurer.
Look at .040 gaskets (Cometic) or Mr. gaskets are .042 (but 4.100 bore)
