Another bad oil pump?
<img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
thanks
mike
thanks again
<strong>When you replace the pump at least check the bearings. If the bearings look good just put the pump in if the bearings are worn but not blackened or chewed up replace them if they are blackened or chewed up then it needs to be torn down and cleaned and rebuilt.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">how do you get to the bearings when you change the pump with the engine in the car? or are you assuming we would be taking the engine out? I couldnt get to even the front bearing when i did the cam change...
I don't think anyone really knows for sure if the '02 or ls6 stock pump problems have been addressed. I know the 01's still had some problems. If you get a modded one, at least you'll know for sure and have piece of mind. I think that alone is worth the few extra bucks. Also, if you do a search, there is at least 1 person who modified his own pump. Maybe you can find him and email him.
Good luck.
