Need help...burning oil after heads/cam
I installed TR heads and cam about 2 months ago and I am stil burning oil. I believe it is only comin from the driver side. It puffs out when I start it up and it really comes out in te uper RPMS. Can the valve seal be cracked or something? I dont think it woud be the ring because it si fairly new unless they dropped somehting in there. I will run a compression test as soon as I can but doesn anyone have any thoughts? Thanks.
Did you use sealer on intake rocker bolts they break into port when most port jobs are taken to stage 2 level. This would allow vacuum to pull oil in to port.
I didnt dotheob... it for me...if it did break into it..what do i do then??? Whats ur fav song by Iron Maiden by the way...???
I have GTP II heads (ported never run cores) and TR220 cam and have oil consumption problems too. I occassionally get a small puff of blue smoke at startup and on heavy acceleration. My plugs are not fouled either.My rocker bolts were teflon paste sealed. I get about 1k miles a qt if babied, If hard a qt about 300-500 miles. I tried the truck pcv valve but it got worse. I did notice when I did the LS6 intake swap all my intake ports were heavily coated in oil. Next on my list is a compression check. I also have quite a bit of valvetrain noise too.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by iron maiden:
<strong>I didnt dotheob... it for me...if it did break into it..what do i do then??? Whats ur fav song by Iron Maiden by the way...???</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Take out intake rocker bolts and use Teflon paste pipe sealant on them.
Where Eagles Dare, off my favorite album Piece of Mind, which i have on picture disc with extra song Cross Eyed Mary KICKS ***!
Batmobile..we are in the same exact boat man...im doin the compression test i think toorrow to see what i can find. Ill keep u posted n what i find.
Yeah i have that on tape its good, i have been a huge fan all the way back to 1983 Number of the Beast, ive seen them 4 times, is that your fav?
yea i would say fear of the dark is the best...I also like Mother russia...run to the hills.... and die with your boots on.
