Very Technical Head question. Nick Agostino level question.
If you are just boring out the pocket to fit a 1.43" spring and you dont have LS6 castings, you should be good to go. Mine have been perfect thus far. If you are going over a 1.43" spring and need to take out more, you may be going into uncharted waters.
FWIW, I've run hundreds of passes with my 981 springs, push 400+RWHP, and shift at 6800 rpm's.
<strong>It's not the horsepower level that determines appropriate spring pressures, it's a combination of valvetrain weight, cam lobe design, and rpm's.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is true. Who ever told you the spring rate is determined by the HP level is wrong and doens't have a grasp on whats going on in there.
BTW have you ever noticed that spring rates on engines change when the cam or valves are changed. The LS6 01-02 vs. LS1 vs. Comp XE-R, HP levels could all be 450hp because of the displacement and headflow, but the cams could all be different. The more aggressive the load the lighter the valve system or the stonger the springs or both.
Bret
Just found out also that the reason we want bigger springs is because the supecharger keeps addition pressure on the valves (blowing air to the top of the valve making a downward force). It does make sense that this happens and I can not understand why I have not read about that anywhere. This definately needs to be in the equation when getting springs for a high pressure engine.
<strong>I can not understand why I have not read about that anywhere.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Probably because the small amount of pressure increase isnt much of an issue most of the time.
J.
valve job is distorted quicker,valve tip and stem wear quicker, lifter plastic retainers wear faster and lifters get slop causing them to try and rotate, timing chain wears and gets slop in it more quickly causing retarded cam timing. These items are all important to consider when setting spring presssures, dont take this too lightly .
If you don't believe this then contact your cam mfg. and ask them they are the experts.
<strong>I do have to admit that my intial reaction to the Comp Cams 63-26918-16 was that they did look a bit
"weak" for what I am doing.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think #918 is good for your application and i think its pressures are getting close to max you can use before deflating hydraulics.
<small>[ April 03, 2002, 08:29 PM: Message edited by: LS1derfull ]</small>
The LS1 valvetrain is pretty light and with the shaft mounted rocker system, you don't need big ol honkin' valvesprings like the old schooler's think we need.
My $.02
<small>[ April 03, 2002, 12:58 PM: Message edited by: Jackyl_30 ]</small>
