Quick engine removal checklist
Thanks...
disconnect steering shaft @ rack/pinion.
disconnect brake lines @ abs pump motor (i think just the front ones.)
i'll write more if i think of anything.
Give me a yell if you could use another set of hands. I'll be out of town most of this weekend, but I'll be back Sunday.
BTW I still have the lugnut I borrowed. I'll get it back to you soon before I forget.
Mark
I'll hit you up on that offer of an extra set of hands... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I'm planning to get eveything disconnected and set Saturday.. Then see if I can get my Dad to come down and give me a hand with the actual removal..
Front brake lines from ABS unit. You'll need to remove a sheet metal cover to get the brake lines free from a plastic clip that secures the brake lines to the fender - sounds simple but it pissed me off!
Steering linkage from steering rack.
Braided ground wire on drivers side from fender to block.
Obviously all wiring connectors on top of motor (injectors, coil pack cluster connector, TPS, ECT, IAT, MAF, etc, etc...), but also the MAP sensor on the back of the intake, the vaccum line at the back of the intake, AIR hoses to the exhaust, and don't forget, there's a couple of ground connectors on the back of each head.
Down low, you need to disconnect the O2 sensors near the control arms, disconnect the crank timing sensor (located just above the starter motor), the oil level connector, the power connector from the alternator, ground cable to passenger side tranny mount, ignitions switch wire and power wire to starter motor (I simply pulled the starter out), and all the tranny connectors. If it's a manual, disconnect the clutch hydraulic line from the slave cylinder.
Take the A/C compressor off, it's easier than disconnecting the A/C lines and then re-charging the system.
Guess I can't think of any more off the top... take it slow and easy, in case you forget something, you want to spot it before you rip it apart.
Now that I have totally side tracked your thread. Back to engine pulling ! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Mark
