Car chatters a little bit upon light accelleration even in neutral... Clutch?
When I am in neutral and press the gas just a little bit, the steering wheel shakes a little bit like something is not right.
I am getting no KR but was wondering if it could be the new Cartek clutch. The wierd thing is that I didnt even have the vehicle in gear.
I was thinking my pulley as well maybe but I dont think so.
I dont know, I guess this could be normal, Its just with everyting that has gone wrong so far, I wouldnt be suprised.
Re: Car chatters a little bit upon light accelleration even in neutral... Clutch?
Well this most certainly isn't an internal engine problem, but I had the same problem as you. When I installed my RAM clutch sometimes I would get clutch chatter in neutral and I would have a hard time getting it into 1st and reverse. My McLeod adj master was not adjusted quite right. 1/2 turn of the cylinder rod (clockwise to increase pedal travel) helped a lot to make the clutch disengage completely (which it was not before). Soooo, adjust your master cylinder. If you don't have an adj master, you need one. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
