Help me pick my valves!
2.02 F6231
1.55 F6232
1.60 F6233
The 1.55's are what you're looking for.
If you can afford it, go with the Ferrea's. If not the Rev's are a little cheaper and Manley's cheaper yet. But I'm not so sure that a few numbers on the flow bench is as important as lighter valvetrain. So the 2002 LS6 valves might be worth trying.
Depending on the valve length, etc. that you are looking for it may be more cost effective to cut down a standard valve (1.60 exhaust, etc.) to the size you want - we do this quite often. This will be much cheaper than going with a custom valve.
Chris
BTW, Janzter, thanks for the part #'s. How could you cut down the '02 ZO6 valves as they are filled with Na and K? They are definately sweet but I don't know if they could work. Thanks.
Also, couldn't one have the stock valves machined down some so they're less tapered than they normally are?
<small>[ April 11, 2002, 11:25 AM: Message edited by: NastyC5 ]</small>
The 2002 LS6 valves are 2.00 1.55 and wouldn't need to be cut. I would think a standard backcut wouldn't be a problem but I can't say for sure. They would flow plenty well (afterall even stock valved heads run well) and would be WAY lighter than any of ther other valves. Thus lighter valvesprings can be used, valvetrain wear/reliability is improved, the engine will rev quicker etc. The larger valves aren't really worth anything on the 3.90" bore. On a flow bench yes, but the strip I doubt it. I KNOW lighter valvetrain will be good for something. FWIW, the Ferrea valves are heavier than the other valves both the Rev & Manley in the same size. But they're not tuliped as much either on the top so compression would be marginally higher. Just some things to think about.
The only benefit I see with larger valves (2.05 etc.) is the ability to use 5 angle valve seats.
And yep, no reason to cut down the LS6 valves.
Chris
<strong>ChrisB, can you elaborate more on what you mean by cutting the 1.60 down? Thanks.
Also, couldn't one have the stock valves machined down some so they're less tapered than they normally are?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Jason99ta said it would take alot of work to get the z06 valves to work on my 98 heads because of the cam base circle or something like that.Also z06 valves are 45 bucks a piece.I already looked into getting them but I have now chosen an alternate route.
