LS1 Hot Cam
Old Apr 11, 2002 | 11:25 AM
ASR OFF's Avatar
Default LS1 Hot Cam
For budgetary reasons, it looks like the Hot Cam is the one for me. I have a 2000 Z28 with SLP LT headers with cats, Stock Heads, Borla cat back, K&N FIPK, and a slp 85mmMAF. I've heard that this cam is "designed" to run with stock configurations. Is that true?? I would also like to pass an emissions "snif test". Will it pass?? How does this cam compromise everyday drivability?? Any input will be appreciated... thanks.
Old Apr 11, 2002 | 11:42 AM
NataSS Inc's Avatar
Default Re: LS1 Hot Cam
As far as I know the Hot cam will work good with stock components and it shouldnt have any problem with the sniffer test (I just ordered my MTI C2 and am a bit concerened about that issue). The hot cam really isnt to "hot" so to speak but it is a good performer.
Old Apr 11, 2002 | 04:44 PM
Trans Am WS6 RGS's Avatar
Just out of curiosity what gains can be expected with the hot cam on a stock engine?
Old Apr 11, 2002 | 05:50 PM
TA_2001's Avatar
Here is my dyno for
2001 transam M6
Lid+HotCam+Catback
http://ls1info.com/article.php?sid=118
Old Apr 11, 2002 | 06:46 PM
LS1derfull's Avatar
The way i see emission testing of Hot cam, it will definitely fail idle testing for excess Hydrocarbons, but that doesnt mean it will fail dyno analysis testing, under driving load i believe it would be harder to detect its presence.
I would like somebody who has tested this theory to speak up. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 11, 2002 | 07:13 PM
mgreen's Avatar
I did the IM240 emissions testing here in Illinois. . .dyno test. . .
Hotcam in stock engine, stock manifolds w/ stock cats. . .EGR and AIR not hooked up. . . resulted in a "Fast Pass" with flying colors.
Friend of mine has hotcam w/ Macs & their hi-flow cats, LS6 intake, no EGR or AIR hooked up, and also did a "Fast Pass" on the IM240.
Old Apr 11, 2002 | 07:20 PM
LS1derfull's Avatar
Thank you, i know this info will help many! What is the diff. between fast pass and regular testing?
<small>[ April 11, 2002, 07:21 PM: Message edited by: LS1derfull ]</small>
Old Apr 12, 2002 | 12:11 AM
ASR OFF's Avatar
That helps... thanks.
Old Apr 12, 2002 | 05:28 AM
LS1derfull's Avatar
ttt.
Old Apr 12, 2002 | 07:04 AM
mgreen's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1derfull:
<strong>Thank you, i know this info will help many! What is the diff. between fast pass and regular testing?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ok, here's mine
My numbers. . . M6z28 hotcam (in at 109*), everything else on engine stock, no rear O2's, LS6 Maf, no egr, no air. (btw, I'll put all the test results in bold)
IM240 Standards 31
HC - composite fast pass - 0.124
Mine - .043
pass
CO - Composite Fast Pass - .693
mine - .077
pass
CO2 - n/a
mine - 1.099
n/a
NOx - N/A
Mine .010
n/a
FINALLY, "OBD RESULT*" ADVISORY FAIL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dyno Settings: 12.4 3500
*next car starts here
These are the results of the Hotcammed (in at 111*) A4, Macs + mac cats + LS6 intake, no EGR, no Air.
IM240 Standards 32
HC – Composite Fast Pass – 0.126
Mine – 0.125
Pass
CO – Composite Fast Pass – 0.773
Mine – 0.754
Pass
CO2 – N/A
Mine – 1.316
Nox – N/A
Mine N/A
Dyno Settings: 12.8 4000
OBD Result* Advisory Pass
Couple things to note. . . the "Standard" changed in the 1 1/2 months that passed since we both tested.
I don't know what the "Dyno settings" means.
Finally, a fast pass is how a BRAND NEW CAR would pass if they were to put it on the dyno. . . it's the fastest you can possibly pass the emissions test, ~30 seconds.
You can spend up to 2 or 3 minutes, and they drive it to a higher MPH, and thus your emissions *MAY* go down slightly, or maybe they increase their numbers that you can pass with.
OBD Result. . . this is in regards to finding any MIL's (trouble codes) (SES lights, etc) in the computer.
The second car had LS1 edit in place and removed all/any codes, and they were NOT detected by the emissions place.
This is significant becuz it shows (IMO) that we can have no cats, no rear O2's, etc. etc., and just delete codes or modify the computer so it doesn't run the checks.
Illinois will eventually test this way. . . no actual emissions test, they're just gonna scan the PCM to see if there's any codes.
MIke
