Oil Got Tested
Old Apr 11, 2002 | 05:53 PM
PewterFormula02's Avatar
Default Oil Got Tested
I had my oil analysed and what they found was high levels of copper. What they said 60-70parts per million(not sure of the units, just the #'s) was normal on a gasoline engine. Mine had over 100ppm. Ok now what does that mean? high levels of copper in the oil, what is made out of copper that the oil passes through?
I don't have the sheet with me it's in the mail as we speak, but I was too egar and phoned them to find my results. The level of copper is what concerned them.
Any help would be great
Gary
Old Apr 11, 2002 | 06:30 PM
Fulton 1's Avatar
Default Re: Oil Got Tested
This seems to be a common occurrence with the LS1's. There was a thread a while back discussing the high Cu count.
I don't have my sheet handy, but my first reading (~7600 miles and internally stock) was also around 100ppm. Blackstone Labs suggested that it could be the oil, but I contacted Redline and they told me they do not use Copper as an additive. Haven't really pursued it since I was planning on doing another analysis within the next few months. I'm also wondering what the contributor could be.
Old Apr 11, 2002 | 06:39 PM
Skelton's Avatar
Copper is used in bearings. It usually means excessive bearing wear since its not the outer layer. The only way to tell would be to pull the pan and look. It may be normal.
Old Apr 11, 2002 | 06:40 PM
LS1derfull's Avatar
I dont mean to scare you but the only part made with copper i can think of is BEARINGS. I would cut open your oil filter and examine filter media for potential problems.Especially before removing oil pan or anything!
<small>[ April 11, 2002, 06:41 PM: Message edited by: LS1derfull ]</small>
Old Apr 12, 2002 | 12:00 AM
Paulie's Avatar
Here are my oil test results back when the motor was stock internals. Car is a 2000.
Oil Tests - (ppm)
First Test / 7800miles
Cr 1
Cu 108
Fe 43
Pb 6
Sn 7
Al 6
Si 36
Second Test / 27000miles + tons of racing
Cr 1
Cu 32
Fe 37
Pb 6
Sn 7
Al 8
Si 7
Old Apr 12, 2002 | 12:02 AM
Paulie's Avatar
My two oil test sheets are here:
www.fasta4racing.com/paul/oiltest1.jpg
www.fasta4racing.com/paul/oiltest2.jpg
