Quench area questions
On the flip side..If on my 11.5 to one motor..if I got head gaskets to get a dimension closer to the ideal .035 quench area....yes..compression would be bumped..but would the smaller more active quench area help fight the detonation associated with a higher CR engine?
Anyone out there have knowledge on this and the benifits of quench and how it relates to LS1s?
I just added them to my new engine @ .078
Will post if I have any detonation issues. My mechanic laughed about it too. People prefer to sell complete engines rather than just a gasket I guess.
Sometimes analyzing numbers too closely is just ****. It's only a 30% increase in thickness. LT1's have run up to Double thickness without any detonation issues. Whereas the SC'd LT1's that were using double thick gaskets listening to quench arguments went back to a single that improved quench but raised the compression. With the single and higher C/R the detonation returned. With the double gasket and lower C/R and worse quench, detonation disappeared.
I wouldn't go past .078 tho.
<small>[ April 13, 2002, 12:22 AM: Message edited by: MelloYellow ]</small>
I have *never* seen anyone use headgasket thickness to lower compression and have good results, I would be interested in any evidence. I have seen quite a few motors run on compression ratio's and pump gas higher than you would think possible (12.3-12.5:1 LT1's) - and they all shared excellent quench characteristics.
The headgasket is not the place to lower compression - piston dish and chamber volume are where you need to do that.
Chris
And does anyone know the stock LS1 dimensions?
Im looking through my build sheet right now trying to determine what the quench area distance would be. Is "deck clearance" the distance between the piston top at TDC and the block deck? If so then that would be .002 on my engine, combined with a .054 head gasket would give me a .056 quench dimension...is this correct? My compression is 11.5 to one. Would a better quench dimension of .035-.040 be a step forward in detonation fighting even though compression would be bumped up?
I believe the stock pistons come +.006 out of the hole if that helps. But a couple people joked about GM production line tolerances, so +.006 is pretty exact. Dunno what production variance would be.
Also, does the stock .0524" gasket compress when TQ'd down?
Milling heads would reduce quench height, eh? but how does bowl porting offset it?
FWIW, I'll post my results. Won't be blown for another 3-4 months, so might run 89 Octane and ATAP the results with my .078" Head Gasket too.
<strong>No Im not going forced induction. Im just trying to learn a little more as it relates to my ARE motor build up. This subject is rarely talked about and wanted more info on it.
Im looking through my build sheet right now trying to determine what the quench area distance would be. Is "deck clearance" the distance between the piston top at TDC and the block deck? If so then that would be .002 on my engine, combined with a .054 head gasket would give me a .056 quench dimension...is this correct? My compression is 11.5 to one. Would a better quench dimension of .035-.040 be a step forward in detonation fighting even though compression would be bumped up?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Your quench is close to stock, i would leave it that way, not reduce it or raise compression. You should be ok, thats what knock sensors are for, or program setup for less timing advance with 11.5 to 1. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Chris
<strong> I have *never* seen anyone use headgasket thickness to lower compression and have good results, I would be interested in any evidence. I have seen quite a few motors run on compression ratio's and pump gas higher than you would think possible (12.3-12.5:1 LT1's) - and they all shared excellent quench characteristics.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Have you ever seen bad experiences with thicker headgaskets? Specific examples?
