Ordering My Cam Kit (TSP)
Old Jan 22, 2007 | 10:56 PM
TORCHD 02 TA's Avatar
Default Ordering My Cam Kit (TSP)
Well tomorrow i will be orderign my cam and the kit from TSP.. tell me if i am forgetting anything?!
KIT
Cam - 228/232 .588/.595 110+4 (ICL 106)
Springs - PRC Dual Springs or Patriots???
Retainers - TI Retainers
Seats/Seals - Included In Kit
Push Rods - Hardened forgot the brand they use.. But 7.4" or 7.425?? I have searched that the 7.425" will quiet the valve train down a bit.
Reuse Stock Locks???
Separately
* I will be buying an LS2 Timing Chain
* I will be buying a new oil pump... Is there a difference between and LS6 (ported and shimmed) Vs. SLP??
* Hypertech 160* T-Stat
* ASP UDP
Gaskets
    Let me know what you all think. Am i missing anything?
    Old Jan 22, 2007 | 11:06 PM
    NviouSS's Avatar
    you shouldn't need new valvecover gaskets. other than that it looks like you got everything.
    Old Jan 22, 2007 | 11:16 PM
    i threw that out jsut as a pre caution... That is all
    Old Jan 22, 2007 | 11:49 PM
    PREDATOR-Z's Avatar
    KIT
    Separately
    * ASP UDP
    Gaskets
      Patriot kit is more complete,
      Get the LS2 kit with gears
      Yes on new locks (but are in Patriot kit)
      Stock LS6 pump or LQ4 is enough and plenty
      You can get a gasket/bolt kit
      7.425s p-rod
      I prefer March pulley as it has better harmonic control.
      Mark
      Old Jan 23, 2007 | 01:39 AM
      yak's Avatar
      yak
      I have a slp ported pump. I generally hate SLP stuff but, I think it was the best 170 I ever spent. I have 55 psi at idle and 75 plus psi at wot.
      Old Jan 23, 2007 | 01:20 PM
      7.425s p-rod
      Mark
      Do you have more info on the Patriot kit?
      I am going to get the LS2 chain with the stock gear it will be fine
      Is there a difference between LS6 and SLP?
      Where can i get the gasket/bolt kit from?
      I have heard bad things with March
      Old Jan 23, 2007 | 06:33 PM
      well i ordered the cam today
      I will have the gaskets, springs, oil pump, push rods, seats/seals by this week. And the cam will be here by prolly tuesday next week.. Fvck i thiink i forgot to order the LS2 timing chain SOB....
      Old Jan 23, 2007 | 11:10 PM
      yak's Avatar
      yak
      i wouldn't get the chain through a local dealer, I made the mistake of paying out the *** at a local dealer with mine. I think Scoggin dickey has then for like 30 bux.
      the patriot kit comes with everything you need springs, locks, retainers, seats and seals. you can use the stock gear, I did and I have never had any isues.
      Old Jan 23, 2007 | 11:33 PM
      GreenBlood's Avatar
      torchd, ur car is gonna sound sick with a cam...i don't live that far from you when I am back home from school...I live in schiller park...i'd like to hear that thing in person when i come back this summer...
      Old Jan 24, 2007 | 12:29 AM
      PREDATOR-Z's Avatar
      Info on their site
      Yes it will work but matching gear set is the way to do it.
      You do not need a ported pump, those are overkill in most application unless you plan on going to past 7K rpm, which I doubt with your cam.
      TSP
      You heard wrong, I have 2 of them on on each car and the one on my Z's been there for 2+years. Good item with real dampening characteristics.
      Old Jan 24, 2007 | 10:14 AM
      sure PM me some time
      Old Jan 24, 2007 | 10:15 AM
      Info on their site
      TSP
      Got all the accessories from TSP
      I orderd the LS6 ported and shimmed from TSP.. Just gives better oil pressure that is a good thing
      I will buy and LS2 chain
      Got the gasket from TSP too
      still not sure on a pulley
      Old Jan 25, 2007 | 06:37 PM
      HotWhipT/A's Avatar
      When you putting this in? I wanna hear it!!!
      Old Jan 25, 2007 | 06:41 PM
      99kamarokid's Avatar
      what are the gains from this cam compared the the 228r?? thats the one i was going to get but if i could bump it up i will.. but this is my everyday car in the summer..
      Old Jan 25, 2007 | 06:46 PM
      one more thing.. i know what the 110 is but whats the +4??
      Old Jan 25, 2007 | 07:54 PM
      Eric the car goes in the shop Monday, Feburary 5th
      Can not wait
      Old Jan 25, 2007 | 07:57 PM
      I have no idea what the gain is over the 228r. Well the fact that it is a split cam with the exhasut being bigger it will have a little more affect.
      the +4 means that there is 4 degrees grounded into the cam, so when you go and install it, you can line it up dot to dot..
      Old Jan 25, 2007 | 08:00 PM
      noxiouSS's Avatar
      yeah. i have always wonder what that means.
      Old Jan 25, 2007 | 10:25 PM
      HotWhipT/A's Avatar
      So what brand of cam is this? I didn't see yours on TSP. I knew what the +4 is, but I don't really know why you put a cam in with a different degree than zero? Tell me!
      Old Jan 25, 2007 | 11:29 PM
      Eric.. My cam is a custom grind by Comp. There is a lot to learn why people grind it with it degreed. It helps a bunch of stuff. IE: TQ, HP DCR.
      But i promise when i get it installed i will get sound clips
