rev kit questions
Old Jan 23, 2007 | 02:11 PM
eLTwerker's Avatar
Default rev kit questions
I was looking at cams for my TA(mods in sig) and was suggested that a rev kit would help protect the valvetrain to allow me to spin the motor past 6k. Maybe up to 6500-6800 even. Any thoughts, opinions etc.. will be greatly appreciated.
P.S. will the AFR rev kit work with Comp R lifters? Any body know how much the AFR kits cost? Thanks!
Old Jan 23, 2007 | 02:45 PM
Patrick G's Avatar
LS1 Tech Administrator
Moved from advanced tech section. Many more eyes in here.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 23, 2007 | 03:02 PM
ROCNDAV's Avatar
Does anyone even make a rev kit? I've seen a couple of pics posted on LS1tech over the years, but they were all custom / self built kits.
Old Jan 23, 2007 | 03:16 PM
Tootall's Avatar
ARP main studds, ARP rod bolts, . . . how many miles are on the engine?
Old Jan 23, 2007 | 04:02 PM
eLTwerker's Avatar
only 28.5k, but I'd like to be able to spin to 6500-6800. Taking off the heads is not really in the budget, so if a rev kit won't do it, then it's not worth it.
Old Jan 23, 2007 | 04:10 PM
Tootall's Avatar
I've never heard of a "rev kit" but you would need supporting mods to do that, what kind of "hotcam" do you have, what are the specs?
Old Jan 23, 2007 | 05:46 PM
JPH's Avatar
JPH
as long as you got good valve springs, you will not need a rev kit. crane #144833 or comp #26921 stuff will be fine.
Old Jan 23, 2007 | 09:58 PM
BOWTIE's Avatar
Only rev kit that I was aware of was one built by the old Agostino Racing Engines. They basically took an AFR LT1 kit and made seperate parts for ti to fit the LS1. Unfortunately back in the day when they were producing these (1998-1999 time frame) there were not a lot of cams that required them so the demand was low and they stopped producing them. I called them a few years ago before the turmoil, and they said they were no longer available. Too bad.
Old Jan 23, 2007 | 10:46 PM
ROCNDAV's Avatar
I saw one on eBay last year and asked the guy about it. He said it was from some place in Texas or Florida (I forget now). Another forum member made his (nice looking purple anodized pieces). Too bad they arent available.
Old Jan 23, 2007 | 11:31 PM
BOWTIE's Avatar
Just noticed you have an LT1... So yea, the AFR Rev kit will work for you. In my opinion they should help out any hydraulic roller setup. It will allow you to run less valve spring so you do not have the hydraulic lifter colaps and then pump up problem yet you can still maintain the same amount of valvetrain control that would require considerably more spring if you did not have it. The advantage is it applies the pressure to the lifter housing instead of directly to the lifter plunger.
Old Jan 23, 2007 | 11:40 PM
hammertime's Avatar
If I'm reading right, the original poster is asking about a rev kit for a 1995 TA, which is an LT1, so SBC parts should fit the bill. I'm curious what springs are in your GTP heads and why you couldn't reach your goal with them?
Looks like AFR's kit would work fine...
http://www.airflowresearch.com/hydra_rev.php
Hydra-Rev is available now for Chevrolet V8 small block and V6 engines except the cast iron LT1 Impala and Vortec truck heads, Pro Action Iron Lightning or Dart Iron Eagle.
edit - Bowtie beat me to the punch while I was watching Salma Hayek on TV
Old Jan 24, 2007 | 09:14 AM
eLTwerker's Avatar
I've got the hotcam now, but will be getting a bigger cam. Springs I have now don't have enough pressure for the size cam I'm looking for. Was gonna go with the Comp 280XFI but I'm re thinking that one. I want something to spin a little higher than the 280XFI. I was advised a rev kit would help, but is it worth the price (which I still don't know btw)
