Which timing chain?
Old Jan 23, 2007 | 03:15 PM
b3av3r's Avatar
Default Which timing chain?
Getting all my parts together for a H/C swap and I am a bit confused on which timing chain to go with. I see several listed on Thunder's website, but which one is worth the money?
Also is the QTP plate worth all the $$$$?
thanks
Old Jan 23, 2007 | 03:21 PM
TS99V6's Avatar
thanks
Just go with a LS2 Chain from texas-speed.
Old Jan 23, 2007 | 05:16 PM
slow trap's Avatar
+1
that is all i did .
Old Jan 23, 2007 | 05:39 PM
snakesmash'nLS1's Avatar
[QUOTE=b3av3r]Getting all my parts together for a H/C swap and I am a bit confused on which timing chain to go with. I see several listed on Thunder's website, but which one is worth the money?
wow I was about to ask the same question. Not trying to steal the tread but what is the advantage of a double roller timming chain?
Old Jan 23, 2007 | 05:40 PM
JPH's Avatar
JPH
jp performance set up here.
Old Jan 23, 2007 | 05:42 PM
brad8266's Avatar
most go with the ls2 chain. A double chain is stronger, its got 2 chains instead of one.
Old Jan 23, 2007 | 05:49 PM
slt200mph's Avatar
LS2 chain here..paid about $27 for it at the dealership where I work.. it has 41,000 miles on it and is doing fine ..
Old Jan 23, 2007 | 07:35 PM
99blancoSS's Avatar
ls2 in my first install, rollmaster adjustable double is my current.
Old Jan 23, 2007 | 08:04 PM
Order 66's Avatar
Ls2 chain is all you need. And yes the qtp 2 piece timing cover is worth it. Already planning on my next cam.
Old Jan 23, 2007 | 08:58 PM
cantdrv65's Avatar
Post
Rollmaster single here....No problems.
