Cam install????
Old Apr 15, 2002 | 09:23 PM
SOCALSS's Avatar
Default Cam install????
I got a head/cam package. The cam is .566/.566-222-222/112.0. Do you guys install the cam straight up or retarded or advanced? Any info would be greatly appreciated!!
Old Apr 15, 2002 | 09:41 PM
TimZ28's Avatar
Default Re: Cam install????
Unless you have an adjustable timing set or are going to install an offset bushing you will have to install it dot to dot. There is probably advance ground into the cam but you will likely make more top end power installed straightup (this is not necessarily dot to dot).
Tim
Old Apr 15, 2002 | 09:47 PM
SOCALSS's Avatar
I dont have an adjustabe timing set or offset bushing.
Old Apr 15, 2002 | 09:48 PM
SOCALSS's Avatar
I dont have an adjustabe timing set or offset bushing.Also what do you think about this cam??
Old Apr 15, 2002 | 10:36 PM
TA_2001's Avatar
Its safe to say that dot-2-dot is a good
place to start..
make it look like this
http://www.ls1info.com/article.php?sid=192
