Question about oil level and pressure.
Old Apr 18, 2002 | 11:52 PM
RockIt's Avatar
Default Question about oil level and pressure.
As much as I have done you think I would know this, but is 6 quarts of oil safe? I ended up doing the oil change and put 6 quarts in by using the wrong specifications sheet(corvette) <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> .
I checked the oil level and it was half way up the arrow, above the full line. Should I worry about it or just make sure I put in 5.5 quarts the next time around?
The oil pressure reads over 40 when cold and over 60 past 2500. As it starts to warm up the pressure does drop some. At WOT it almost pegs the gauge on the 80 mark, but after the engines been running for 10 min it drops down to about 70.
Normal?
Here is a pic of my 95 Trans Am's dirty engine bay.
<img src="http://www.hpsalvage.com/ta/DirtyLS1.JPG" alt="" />
Old Apr 19, 2002 | 02:26 AM
MTWallet's Avatar
Default Re: Question about oil level and pressure.
I just changed my oil and manual says not to check the level cold....do it when warm...otherwise you might get a higher than normal reading. sorry, that's all I know.
anyone else? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 19, 2002 | 02:32 AM
CKZ's Avatar
CKZ
I think my manual says 6 quarts. Anyway, thats what i put in.
Old Apr 19, 2002 | 02:40 AM
MTWallet's Avatar
CKZ
Do you have the larger than normal oil filter? i just put in a standard size K&N with five quarts.
Old Apr 20, 2002 | 06:32 AM
Patman's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MTWallet:
<strong>CKZ
Do you have the larger than normal oil filter? i just put in a standard size K&N with five quarts.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Five quarts is too low, you should be at 5.5, and most people run 6 quarts even with the stock filter. Autocross guys sometimes run 7 quarts with the longer filter.
Old Apr 20, 2002 | 01:55 PM
CKZ's Avatar
CKZ
I run the stock size filter. And, from now on, Castrol GTX oil. Synthetic is too damn expensive!
