New cam.... what expectations
Old Apr 19, 2002 | 09:59 PM
2kredCSS's Avatar
Default New cam.... what expectations
Well I just bought a cam from, Ragtop99, Thanks Joel I was just wondering what I could expect with the mods below before headers??
specs are
duration @ .006 271
duration @ .050 218
lsa 114
lift .563
I will be installing 918 springs and ti retainers. Just wondering what I may see before the flp's go in.
PACE ls6 maf, lid, FTRA, asp pulleys, slp loudmouth, Ported Throttle Body -- basically all motor modifications.
<small>[ April 19, 2002, 10:09 PM: Message edited by: Jim P. ]</small>
Old Apr 20, 2002 | 06:57 PM
2kredCSS's Avatar
Default Re: New cam.... what expectations
TTT, common guys please
Old Apr 20, 2002 | 07:03 PM
LS1derfull's Avatar
Jim i saw 25 hp with similar cam swap only on a 112* on a very stock 2001 Z28 m6, no exhaust mods.
Gains would be higher if i raised stock rev limiter.This gain is based on track mph gains before and after cam swap.
<small>[ April 20, 2002, 07:04 PM: Message edited by: LS1derfull ]</small>
Old Apr 20, 2002 | 07:05 PM
2kredCSS's Avatar
cool... is 112 lsa much diff then 114?
Old Apr 20, 2002 | 07:10 PM
LS1derfull's Avatar
No dyno graphs ive seen are almost identical, 112* is choppier at idle and 114* should have maybe 200 extra rpm before power falls off.
Old Apr 20, 2002 | 07:13 PM
Tom99SS's Avatar
Jim,
I have this exact same cam. Ragtop99 is one of the reason I went with this cam, he had success with it. I also have no exhaust mode except with the SLP dual/dual option for SS. Here is a link to my dyno I had Dyno Graph .
I think once I add MAC headers I should see additional 30 rwhp at least.
You will really like this cam and it does like to rev.
- Tom
Old Apr 20, 2002 | 07:15 PM
2kredCSS's Avatar
WEEEE... did you need programming? I cant wait to get this thing in.
<small>[ April 20, 2002, 07:18 PM: Message edited by: Jim P. ]</small>
Old Apr 20, 2002 | 07:32 PM
Tom99SS's Avatar
When I first had the cam in I did not have custom programming. Played with the idle set screw to have the idle at 750rpms. TB is drilled to 13/64th. I had dyno tuning done a couple of weeks ago. It got me about an extra 10rwhp. It really is not needed but you will be a running a little rich after the cam install.
Have fun and remember, raise the rev-limiter to really enjoy this cam.
- Tom
Old Apr 20, 2002 | 07:37 PM
2kredCSS's Avatar
Do you have aol IM or anything? I have a few questions I'd like to ask you... like how do I mess with the idle set screw and so on
Old Apr 21, 2002 | 11:50 AM
Tom99SS's Avatar
Jim,
Email me. I had set an email to somebody else on how to do this. I will email back with what I did to up the idle without programming.
- Tom
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Apr 21, 2002 | 01:05 PM
flyin red TA's Avatar
I have this cam with mac headers and mac cats, my car did 346hp and 359 lb ft of torque on the Speed Inc dyno.
Old Apr 21, 2002 | 04:15 PM
2kredCSS's Avatar
JimTA, Are you a m6 or an a4? I only ask because I recently pulled 340/340 without the cam or headers.
Old Apr 21, 2002 | 04:20 PM
2kredCSS's Avatar
wow 6500, it may just be me but that seems pretty high
Old Apr 21, 2002 | 07:09 PM
A4. What year is your LS1?
Old Apr 21, 2002 | 08:39 PM
2kredCSS's Avatar
my car is an M6 2000. I am getting butterflies about getting this cam
<small>[ April 21, 2002, 08:40 PM: Message edited by: Jim P. ]</small>
Old Apr 21, 2002 | 11:20 PM
I think you could go a lot bigger with an M6...up to the thunder 224 without much loss of drivability over the 218.
Old Apr 22, 2002 | 12:10 AM
2kredCSS's Avatar
Ok cool I e-mailed you.
Thanks for your info LS1derfull. WHat should I set my rev limiter at once I get this cam installed? any ideas?
Old Apr 22, 2002 | 12:57 AM
LS1derfull's Avatar
Well if you limited by HPP to 6600 than set it there and try to shift right at 6500 if you can.
If you are going LS1 edit or other custom programming i would have it set at7000 so it wont bother you for other mods down the road. IMO
Old Apr 22, 2002 | 03:17 AM
2kredCSS's Avatar
well I've already bought the 218 so we'll see what happens.
