Idle set screw question
Old Apr 20, 2002 | 07:48 PM
2kredCSS's Avatar
Default Idle set screw question
Is there really a way to raise and lower the idle speed on these cars? if so How can I do it? I thought it was computer set. I would like to drop my idle a bit for my cam. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Apr 20, 2002 | 07:51 PM
NoGo's Avatar
Default Re: Idle set screw question
You may want to raise your idle a bit for your cam. Dropping the idle on a large cam will generate misfire codes and make the car difficult to drive.
You can raise your idle up to 200 rpm using the idle set screw before you set an SES light.
Old Apr 20, 2002 | 07:53 PM
2kredCSS's Avatar
I know but if it idles fine. I may want to drop it a bit for a lope.. Can anyone explain how to do this?
Old Apr 21, 2002 | 09:47 AM
AgaveCorvette's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jim P.:
<strong>I know but if it idles fine. I may want to drop it a bit for a lope.. Can anyone explain how to do this?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">you want lope? get a bigger cam. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 21, 2002 | 10:30 AM
WMSuperSport's Avatar
It will lope if you drop the idle, but will drive drifferently as well.
Old Apr 21, 2002 | 10:44 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The only way you'd be able to drop the idle via the set screw is if the TB blade is already partially cracked open. You can turn the set screw all the way back if it's not already. If it did not crack the blade open any, then the only other way to do it would be to close the hole in the TB blade and re-drill a smaller one.
__________________
Old Apr 21, 2002 | 11:45 AM
2kredCSS's Avatar
Ok, Im just ancy to get this cam in its not a huge cam but I wanted a daily driver so we'll see
218/218 .563 114 lsa
Old Apr 21, 2002 | 01:01 PM
flyin red TA's Avatar
<strong>Ok, Im just ancy to get this cam in its not a huge cam but I wanted a daily driver so we'll see
218/218 .563 114 lsa</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You don't have it in yet??? I have it, and it lopes pretty good with the idle raised and a big hole in the TB blade. Lopes just as hard as the cars with hammer cams and thunder 224 cams.
Old Apr 21, 2002 | 04:17 PM
2kredCSS's Avatar
Great I can't wait to hear it
Old Apr 21, 2002 | 07:39 PM
PhillyWS6's Avatar
you actually drilled a hole in the TB plate? What would that do as far as performance. I would amagine it would hurt the performance?
Old Apr 22, 2002 | 12:14 AM
PhillyWS6's Avatar
The screw is attached to the TB where the the shaft rests when the car is at the idle postion. It is a small tork 15 nut on the underside of the plate. Hope this helps if not let me know and I will try to emplain it better.
