What do you think of this cam only setup???
Old Jan 25, 2007 | 10:43 PM
CaMaRo67RS355's Avatar
what do you think of the 18th reply on here i made about the cam kit and bolt is that what im needing?
Old Jan 25, 2007 | 11:08 PM
JRracing's Avatar
Yes, that is what you need.
Old Jan 26, 2007 | 07:52 AM
h8s2w8's Avatar
Just wanted to add to this post that if I were a manufacturer of car parts I would tell everyone and their brother they needed to buy my parts. For valve springs the patriot dual golds would work out well for you. I realize you dont buy anything cheap for your car but why spend money when you dont need to?? 250 bucks or what do comp springs run now 500?
just my .02
Old Jan 26, 2007 | 08:57 AM
HaulinHawk's Avatar
I am runnin a ls2 chain on mine,and stock lifters,and its doin great.You will love the cam!!!
Old Jan 26, 2007 | 12:28 PM
u only pulled 370rwhp on the cam + bolt ons? im hoping to do cam only and get 400 rwhp hopefully......
Old Jan 26, 2007 | 12:52 PM
HaulinHawk's Avatar
Yep,dyno #'s dont really mean much to us auto guys,its the mph we look at 117mph aint too shabby ,looking for 119-120mph with the 90/90setup,cutout and good weather.
Old Jan 26, 2007 | 01:22 PM
i just figured it would be more thats all
Old Jan 26, 2007 | 01:30 PM
TORCHD 02 TA's Avatar
I just ordered my cam kit from TSP
Cam Pkg- Dual Springs, TI Retainers, Seat/Seal and 7.425" Push Rods= $707
Gasket Pkg- Front Cover Seal, Front Cover Gasket, Water Pump Gasket, Oil Pump O-Ring, Crank Bolt= $43.99
LS6 Oil Pump Ported and Shimmed= $129.99
LS2 Timing Chain= $35.99
Grand Total: $916.97
Old Jan 26, 2007 | 01:39 PM
SLP99sscamaro's Avatar
what do you think of this is this a good deal cause its a matched set?
http://www.lgmotorsports.com/catalog...oducts_id=1399
is there anything else i'll need to complete my cam swap besides the timing chain & oil pump that isnt in that kit? do i need to get new gaskets or are they reusable?
For having 2 strip cars you really are not sure of some stuff ???
Kind of skeptical
Old Jan 26, 2007 | 01:44 PM
again the 67 is not a LS1 and doesnt have anything streetable on it. the 00 SS was just purchased not too long ago my dads friend had it built and then we got it i have all the specs on it but i mean i dont know the boundaries between whats streetable and whats not.
Old Jan 26, 2007 | 10:03 PM
mullenh's Avatar
he has an 11 second car man, think about it... that is hauling butt. Some heads will wake the cam up even more, 40+ hp.
Old Jan 27, 2007 | 10:09 AM
  #32
i just have seen more power on the dyno with that cam than what he put out. also i think he was running the m/t streets and skinnies to get in the 11's. im just running street rims with drag radials.
Old Jan 27, 2007 | 10:47 AM
  #33
cws T/A's Avatar
You will more than likely hit 400+ with a stock rearend /6speed with a g5x3 cam .
An auto with 4,000 stall + a 12bolt , 370 is damn good
What your car makes or runs is in the combo .
Old Jan 28, 2007 | 11:00 AM
  #34
im still trying to figure out what cam its alotta money in a cam swap so i wanna make sure i do it right the first time and pick the right cam.
Old Jan 29, 2007 | 10:00 PM
  #35
what length should i get the pushrods? anyone purchased that slp timing chain kit and oil pump??
Old Jan 30, 2007 | 01:01 AM
  #36
cws T/A's Avatar
7.425" pushrods
Patriot Gold spring kit .650''
LS2 timing chain/ gears set
Melling oil pump
Through in a 25% underdrive pulley
Old Jan 30, 2007 | 09:00 PM
  #37
mullenh's Avatar
7.425 here but that is just part of the picture
