What do you think of this cam only setup???
Old Jan 24, 2007 | 11:55 PM
CaMaRo67RS355's Avatar
Question What do you think of this cam only setup???
getting ready to go with a cam not sure exactly which but really leaning more towards the LG G5X3 out of all ive seen so far.
im going to change some other stuff while im down there so what do you think of the following if you have any experience with any of the stuff i listed let me know whether its good or bad and also if you have any recomendations on any other parts let me know.
*G5X3 CAM
*SLP Heavy Duty Oil Pump/Timing Chain Package
http://www.ws6project.com/user_stor/...9e302e63bbe2e9
*Comp Cams High Energy Hydraulic Roller Lifters
*Comp Cams Hi-Tech One Piece Chromoly pushrods but what size?http://www.ws6project.com/user_stor/...9e302e63bbe2e9
*What valvesprings, retainers, locks, etc. would you run...
the Patriot http://www.ws6project.com/user_stor/...9e302e63bbe2e9
or
the Comp http://www.ws6project.com/user_stor/...9e302e63bbe2e9
Old Jan 25, 2007 | 05:32 AM
DONAIMIAN's Avatar
You dont need lifters, and if you choose the go with the comp springs, then id just buy the whole package from LG as it would most likley be cheaper than buying everything piece by piece.
Old Jan 25, 2007 | 05:35 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Go get some sleep D!
Old Jan 25, 2007 | 06:43 AM
well the car just turned 55,000 miles and a few people i talked to said they would go ahead and change the lifters just incase. the dude at comp said to go ahead to because 55,000 may not need them now but around 60,000 they probably will and he also said that with running an aftermarket cam that is kind of aggresive he said it would eat the stock lifters up.
Old Jan 25, 2007 | 07:15 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I run my 244/248 on my stock 100,000 mile lifters. Have had 5 cams on the original set. I don't think you have to.
Old Jan 25, 2007 | 07:16 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
However, if you were swapping the heads I would do it. Other than that you are spending money you don't need to with head gaskets/bolts/possibly lifters...ect.
Just some food for thought.
Old Jan 25, 2007 | 11:04 AM
N4cer's Avatar
No need to swap lifters if they're not having a problem and you're not removing heads.
The G5X3 is a great cam. I've seen many happy local guys with that cam, including myself. My tuner just tuned a G5X3 vette with AFR heads and it made right around 470/420.
Old Jan 25, 2007 | 11:17 AM
brad8266's Avatar
stock lifters pretty much last forever, no need to swap em.
Old Jan 25, 2007 | 11:48 AM
DONAIMIAN's Avatar
Unless they turn.
Old Jan 25, 2007 | 12:02 PM
N4cer's Avatar
Just like an aftermarket one ya mean?
Old Jan 25, 2007 | 01:23 PM
what do you think of the valvesprings and oil pump and timing chain i have listed whats the best? i dont buy anything cheap for my car.
Old Jan 25, 2007 | 01:53 PM
what do you think of this is this a good deal cause its a matched set?
http://www.lgmotorsports.com/catalog...oducts_id=1399
is there anything else i'll need to complete my cam swap besides the timing chain & oil pump that isnt in that kit? do i need to get new gaskets or are they reusable?
Old Jan 25, 2007 | 03:56 PM
Old Jan 25, 2007 | 08:31 PM
anyone wanna help me out and comment on this thread???
Old Jan 25, 2007 | 09:31 PM
bobbss's Avatar
Gaskets,front seal and balancer bolt.TSP has a kit.
Old Jan 25, 2007 | 09:32 PM
purdueranger's Avatar
get the kit from LG. I bought my car off of Louis from LG. Good stuff. I have the X4 but my car only leaves the garage maybe 2 times a week now.
Old Jan 25, 2007 | 09:34 PM
N4cer's Avatar
That's where I got my LS6 oil pump and spring kit and gasket kit. I haven't heard much on these LS4 oil pumps. What's the deal on them?
Old Jan 25, 2007 | 10:16 PM
http://www.ws6project.com/user_stor/...a4a31777b07e84
is that the balancer bolt needed?^^^
is this a good cam swap kit?^^^
Old Jan 25, 2007 | 10:20 PM
is it just me or does the LG cam kit seem over priced?
http://www.lgmotorsports.com/catalo...roducts_id=1399
Old Jan 25, 2007 | 10:32 PM
N4cer's Avatar
I know that when we blueprinted my motor the G5X3 came out closer to spec than any cam I've ever seen. And it wouldn't surprise me if LG has strict tolerances on what variances they'll accept to put their name on. If you have the money, do it. If not, no big deal.
