cam help
Old Apr 24, 2002 | 12:20 AM
BYBYC5's Avatar
*Bad Trader*
Default cam help
CompCams Xtreme 228/234 .539/.547 112LSA
how do you think this cam will perform in an A4 and what do you think the idle might do? What kind of a power range will/might it have. ie..mid low end tq....etc...thnx
ps terry im not looking for a cam that peaks real high, i want low/mid "oommff" and top it off on the top end with a good shot of the funny gas.
<small>[ April 30, 2002, 04:45 PM: Message edited by: Grinch ]</small>
Old Apr 24, 2002 | 10:15 AM
Terry Burger's Avatar
Default Re: cam help
Kevin quit being cheap and buy the MMS 229v2.1 cam. It kicks ***!!! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Apr 30, 2002 | 04:46 PM
BYBYC5's Avatar
*Bad Trader*
TTT
Old May 1, 2002 | 11:22 AM
BYBYC5's Avatar
*Bad Trader*
ttt plz
Old May 7, 2002 | 12:31 AM
BYBYC5's Avatar
*Bad Trader*
wow no response on this yet, ill try another ttt <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 7, 2002 | 12:39 AM
Tin Indian's Avatar
In an A4!
Good luck getting it to idle right. You may not want to hear this, but personally, I think the driveability would be terrible. And low rpm throttle response (tip-in) would be sluggish if used in a daily driver with anything less than a 4,000 stall converter. Poor choice
Old May 7, 2002 | 12:43 AM
BYBYC5's Avatar
*Bad Trader*
WOW on that response, but thats the kind of info im looking for.... anyone agree or disagree??
Old May 7, 2002 | 12:57 AM
Tin Indian's Avatar
How bout Comp Cams 220/220 .563/.563 (or equivalent) on a 114 LSA?... Less duration, more lift, and much better street manners in traffic.
<small>[ May 07, 2002, 12:58 AM: Message edited by: Kimchee and Rice ]</small>
Old May 7, 2002 | 02:12 AM
BYBYC5's Avatar
*Bad Trader*
i really want the 112ls
Old May 7, 2002 | 11:11 AM
BYBYC5's Avatar
*Bad Trader*
anymore thoughts,
Old May 7, 2002 | 11:14 AM
I might have my MMS 229v2.1 cam for sale soon... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old May 8, 2002 | 12:32 AM
BYBYC5's Avatar
*Bad Trader*
what are the numbers on the 229v2 i might consider it
Old May 8, 2002 | 11:23 AM
Carlitos's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Grinch:
<strong>i really want the 112ls</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you really want the 112, go with the CompCams XE-R lobes. An XE-R 222/222, .581/.581, 112 will idle very similar to the XE 220/220, .563/.563, 114.
The XE-R lobes have less advertised duration vs. duration at .050" than the XE lobes. For example, the advertised duration of an XE-R 224 is the same as the advertiesed duration of an XE 220. They both have 273 degrees of advertised duration. This means that the overlap area will be similar which is primarily what affects idle characteristics.
'Los
Old May 8, 2002 | 11:47 AM
Raughammer's Avatar
D(irecto)r Pepper
<strong>CompCams Xtreme 228/234 .539/.547 112LSA
.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">In an A4 that was maxed out for the track and one that you planned on turning up around 7300 RPM it would be ok. To make that cam work you would need at least a TP4400 converter, 4.10 gears, more compression, headers, custom tuning, etc. etc.... Again, that is if you want it to work "right". You COULD just put it in and MAKE it work....with less than stellar results.
To summarize...it's WAY too big unless you plan on building your car around it.
Too big? so is the 229/229MMS cam for your stated application.
You did say you wanted low end umph, did'nt you? The bigger you go.... the more "low end" you lose. (generally speaking)
Old May 8, 2002 | 01:34 PM
BYBYC5's Avatar
*Bad Trader*
ok scince we have established that this cam is too big. what am i looking for. i want low/mid tq and power. i want it to peak around 64-6500. i will be on the bottle but i want it a good N/A for street use. any suggestions... anyone got one for sale or trade....thnk for the good info guys
