can you get compression ratio from compression #
Old Apr 24, 2002 | 11:19 PM
2bseen's Avatar
11 Second Truck Club
Default can you get compression ratio from compression #
if I know what compression #s I have per cyl. what else do I need to tell how much compression ratio or can you do that?
Old Apr 25, 2002 | 05:21 PM
MIGHTYMOUSE's Avatar
Default Re: can you get compression ratio from compression #
you can get a general idea from compression numbers, but unfortunately everyone does it differently and uses different gauges.
best bet would be to ask the fellow who u got that 383 from.
Old Apr 25, 2002 | 06:11 PM
WS6underPRESSURE's Avatar
The problem is the cam, the bigger the cam(the more valve overlap) the lower the comp.#, so you really can't tell without more info.
Old Apr 26, 2002 | 08:53 AM
2bseen's Avatar
180# compression with 221/221 558/558 114 cam 10/1000 over head gasket I have been told the lunati motor with factory heads are 11 to 1 I have 72cc heads also
