rebuild help
Old Jan 26, 2007 | 02:23 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default rebuild help
my current motor is completely stock and runs, if i wanted to rebuild it would all i need is forged pistons rings and new rods? or do i need to get the block honed? i ask cause i rather rebuild it before she goes boom.
Old Jan 26, 2007 | 05:26 PM
JPH's Avatar
JPH
depends on what you really want to do. i would upgrade to a better piston say mahle/diamond or je, same with ring set total seal/mahle/ etc. etc. connecting rods compustar/eagle or new rod bolts in yours. the block well likely be honed or bored, depending on piston selection. component selection and budget will determine your build fund.
Old Jan 26, 2007 | 05:28 PM
brad8266's Avatar
Rod and main bearings, forged pistons, rings, forged rods, katech rod bolts, cylinder hone, polish stock crank. All new gaskets too.
Old Jan 26, 2007 | 06:42 PM
LS1Tech Sponsor
so what would i be looking at in rebuilding a motor like price wise me doing all the assembly
Old Jan 26, 2007 | 07:04 PM
david vericker's Avatar
Thunderracing.com - various prices (manufactures)on the parts you need.
Old Jan 26, 2007 | 07:13 PM
brad8266's Avatar
~2k probably
Old Jan 27, 2007 | 09:02 AM
LS1Tech Sponsor
so for another 600 bux i can pick up and assembled short block
Old Jan 27, 2007 | 10:01 AM
brad8266's Avatar
1555 total for this stuff.
GM head/cam gasket package 150
Scat rods with arp bolts 500
Diamond –2cc pistons 565
Rings- 180
Rod and main bearings- 160
All you need after this is a cylinder hone and crank polish.
