Flow numbers for my new LS6 heads
Old Apr 26, 2002 | 05:35 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Flow numbers for my new LS6 heads
Results just completed this evening, the heads are done!
MTI Stage 3 LS6 heads. 2.08" Intake valves, 1.60" Exhaust valves. The cam I will be running has a 0.610" lift. 4.10" test-bore, my actual cylinders are 4.155" though, so they should flow more on my motor <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img src="http://users.ev1.net/~ynot_dv8/flowLS6.jpg" alt="" />
Now, if we just had some intakes that could keep up with these heads <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
1 more week..... the "Cannibal" should be running <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Tony
Old Apr 26, 2002 | 05:44 PM
Terry Burger's Avatar
Default Re: Flow numbers for my new LS6 heads
Looks decent! Not sure if they are worth $4499 but what the hell, its only money. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Apr 26, 2002 | 05:49 PM
Nine Ball's Avatar
LS1Tech Co-Founder
They are worth it to me Terry <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Hard to skimp on a 434ci setup in the first place, and we all know the heads are the most important part. Too bad those LS6 cores still cost $1200 a pair (ouch!). Stage 3 LS1 heads start to taper off pretty quickly after .550 lift, the LS6 heads keep pulling up by comparison.
Tony
Old Apr 26, 2002 | 06:14 PM
Patrick G's Avatar
LS1 Tech Administrator
Man, those are some great looking numbers. Look a lot like my heads up to .400 lift, but yours really pull ahead at .500 and stay ahead! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
You should fly with those. After looking at those exhaust numbers though, you may want to consider a "reverse split" cam Tony. Those exhaust numbers are insane!! <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" /> Tell Jayson and Robert well done.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 26, 2002 | 06:17 PM
I agree heads are the most important part. I wonder what kind of numbers people see from the 6.0L heads. Similar to LS6? Similar to LS6 in exhaust but similar to LS1 on the intake side?
Old Apr 26, 2002 | 06:32 PM
Patrick G's Avatar
Flow numbers I've seen on '01-02 6.0L heads are the same as LS6 heads up to .500 lift. I've seen flow numbers like 275 cfm at .400 lift for 6.0L heads. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Above .500, the LS6s start to pull ahead. For someone running a .550 lift cam, you'd probably never see or feel the difference...the aluminum 6.0L heads are that good.
__________________
Old Apr 26, 2002 | 07:35 PM
Jason99T/A's Avatar
I can shift faster than you.
Very nice numbers Tony! Your setup is going to haul some ***! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Is there anyway you can post a graph comparing a MTI stg 2 LS6 and stg 2 LS1 head for a 3.90 bore? I'm not too woried about peak numbers; more just the shape of the curve,etc.
Jason
Old Apr 27, 2002 | 07:38 AM
VAP's Avatar
VAP
Great post ! Nine ball whats the chances of stating what the port volumes ended up at. Inlet & exhaust <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Do you see now why I was suspicious of those "CLAIMING" 3 5 0 CFM
Thanks
Old Apr 27, 2002 | 08:08 AM
Ken's Avatar
Ken
Thats some great info.
Thats almost exactly what my LS6 heads flowed.
I really happy now!!!!!
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ken
Old Apr 27, 2002 | 08:38 AM
CHRISPY's Avatar
great numbers <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I would like to know the port volume intake and exhaust too if you dont mind.
Cheers,
Chris
PS- When is the due date on the new motor?
Old Apr 27, 2002 | 09:27 AM
Paul J.'s Avatar
Damn Tony, what compression ratio are you going to run? With flat tops and those heads, 13:1 would be possible.
Paul J.
Old Apr 27, 2002 | 09:48 AM
LEO's Avatar
LEO
Tony great #'s on those heads. I know Jayson's got to be happy, Pecos and Robert are top notch. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> I can't wait to see that beast run down the track! <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" /> BTW why don't you "borrow" the intake in Jayson's office for some "testing". <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Apr 27, 2002 | 10:06 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Patrick, my next cam will be a solid roller <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> . For now, it will just be a little Sanders1 hydraulic cam <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> 244/244 .610/.610 112
Jason, I'll see what I can do as far as the flow number comparisons. They flow test every single head they make and keep records of them with the owner's name at the top.
VAP and Chris, I'll see if they can provide the volumes. Chris, I hope to get the motor in the car by next weekend. I miss my car!
Paul, compression ratio will most likely fall between 11.5 to 12.0, not sure right now. I just told Jayson to build the motor like he wanted to and told them that daily-drivability is not my main concern with the car anymore since I bought the new truck/trailer. I do want to run the car on pump gas though, at least until pump gas costs as much as race gas LOL!
Leo, these heads are Robert's doing. That man can port awesome! I'll see if I can get some pics of his work, you all will be drooling when you see his extreme attention to detail.
Tony
Old Apr 27, 2002 | 10:17 AM
John@PACE's Avatar
Tony - Nice numbers! I'd like to see port velocity numbers also if you can get them.
Old Apr 27, 2002 | 11:37 AM
kent's Avatar
Awesome numbers. Sometimes I wished I had got a LS6 heads. Anyway, look forward to seeing great track times posted in the future. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Apr 27, 2002 | 11:42 AM
xxxhp's Avatar
Great numbers Tony <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . I hope that my Stage 3 LS6 will flow the same if not better. I'll be running the same cam as yours but on 114 LSA. The motor compression will be 11.2:1.
Can't wait to get my motor <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Apr 27, 2002 | 11:46 AM
RyanJ's Avatar
SSU Moderator
trailer car? im hanging my head in shame....
Old Apr 27, 2002 | 05:10 PM
Nine Ball's Avatar
LS1Tech Co-Founder
LOL Ryan! I bought the trailer because it absolutely sucks to swap 4 wheels/tires at the track when I get there and swap them back off to put my street tires/wheels on to drive home. HRP is 40 miles from my place, otherwise I'd drive on the slicks haha.
The car will spend about 95% of the time on the new WS6 wheels/tires and prowling the streets of Houston <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Tony
Old Apr 27, 2002 | 05:45 PM
RyanJ's Avatar
SSU Moderator
good to hear....i would hate to think the blue bitch would spend her time on a trailer. nothing is more fun that telling someone the car runs xxx.xx...and oh yeah i drive it everyday. still think you shoulda sold the car to me... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
oh yeah...the Director of Steel needs you to check your mail... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ April 27, 2002, 05:46 PM: Message edited by: Ryan ]</small>
Old May 3, 2002 | 08:04 AM
VAP's Avatar
VAP
You haven't bolted on the heads without measuring the port volumes yet have you ?
Thanks <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
