help needed on ls1 cooling system
i am thinking it has a blocked thermostat what are your thoughts cause i have asked a few other mechanic mates and no one knows anything?
i did notice that the gauge comes down a bit after i go off the high way but only comes down a bit???
any help guys would be good thanks alot
Thermostat (if thermo blocked, the hose leading to it will remain hard while hose from pump to radiator is soft), bubbles in radiator
Tuning of fans
Blocked water passage in block (can be tested via coolant analysis and same issue with hoses)
