ARP Head Studs??
Old Apr 29, 2002 | 03:31 PM
wicked 98z's Avatar
Default ARP Head Studs??
Are they a direct drop in? Or do I have to get some machine work done to the block?
Thanks
Albert
Old Apr 29, 2002 | 03:42 PM
Visceral's Avatar
Default Re: ARP Head Studs??
Direct drop in-out for me.
They also allow you to rather easily slip the heads on and off while the engine is still in the car. The little 12 point 13 mm nut on the main studs is rather disconcerting though. Very small socket/nut to be putting that kinda torque on.
Also, mine tended to "crack" off when I undid them a couple days ago. You know how a bolt kinda makes this cracking noise/motion after its been very tight and might have corroded together with the bolt?
http://www.nolke.com/syty/nextphase/.../bottomend.jpg
Thats what they look like.
Also, last but not least, one of the bolts pulled the stud out with it when I was taking it out. All efforts to get the bolt off the stud have been pretty futile. Might just ask ARP for another stud/bolt pair.
\chrisn
Old Apr 29, 2002 | 05:49 PM
383LQ4SS's Avatar
I absolutely love mine. I will never own another hipo motor without them. Especially after doing head gaskets on a car with regular head bolts VS head studs. Makes Tqing a snap and you know its right.
