Anybody running this Cam or similar? Inside...
Hello all,
just wondering if anybody is running a cam with the same or similar specs to this COMP Cam grind :
.530 / .534 lift
220 / 224 duration
114 LSA
If so, could you please post any feedback on the characteristics of how a cam with these specs would work on a stock heads car with bolt -ons (LT headers, lid, MAF, bellows, and an LS6 intake):
What kind of HP gain? Peaky powerband or more midrange? Idle quality - lopey, too rough, or close to stock? Was PCM tuning or TB hole enlargement necessary? Any other comments / info / advice you could share would be appreciated.
Thanks in advance,
-Bradster <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
.530 / .534 lift
220 / 224 duration
114 LSA
Thanks in advance,
Re: Anybody running this Cam or similar? Inside...
Should be a great cam with stock heads. It's actually not that wild of a cam, especially on a 114. It'll give you a fairly smooth idle. No PCM work will need to be done. It will not be peaky, but more of a wide power band. I doubt you'll have to enlarge the throttle blade hole, but you might have to turn the throttle screw a turn or two. Should be a mild cam, good for daily driving and picking grandma up from church!
Thanks for the feedback, Black Magic <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Although I have no plans for "picking up grandma from church" anytime soon, I do want less of a "Peaky" cam and more of a broader powerband-type cam.
How do you think this cam would compare to the Hotcam (another cam I was considering with similar specs). <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Just wondering
Thanks again,
-Bradster <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Just wondering
Thanks again,
Very similar, except more broad than the Hot Cam. The Hot Cam has always been my favorite cam. I dyno'd 397 with it. It loped pretty good, but I liked that also. IT's just my opinion, but I think the cam your asking about might make less power than the Hot Cam. I liked the peaky power because I have a stick.
Good stuff. Thanks again for the info <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
-B
-B
i had that type of a cam before 224/228 535/538 on 114 went 12.5 @113-114 just cam lid and flowmaster catback on 4.10, nothing eles. with regular 235 street tires. was very pleased with it. i think it will pass somog. its great all around cam.
Awesome <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Thanks for the feedback BadLS1 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-B
-B
