difference in jwis and reinold timing chains?
Old Apr 30, 2002 | 11:57 AM
cablebandit's Avatar
Default difference in jwis and reinold timing chains?
Got my jwis chain in from Katech and have the stock reinold chain here in front of me as well. What is the difference as they both look the same to me?
Old May 1, 2002 | 09:12 PM
JohnR's Avatar
Default Re: difference in jwis and reinold timing chains?
When I measured the links on my JWIS chain I found them to be about 20% thicker than my POS, sloppy stock chain.
Old May 2, 2002 | 03:10 PM
MelloYellow's Avatar
The Renolds uses a cheap brittle iron material, the Jwis uses a much stronger Stainless Steel.
If you twist the Renolds too hard with your hands, it'll snap or crinkle like tin foil. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Throw the Renolds in the garbage!! <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
The Jwis is the same length as the stock renolds.
1 open Q is whether the Cloyes crank/cam gears are larger than the stock gears or if the teeth are beter or the same.
