Question about Comp 'R' Lifters
Old May 1, 2002 | 08:53 AM
TRYMYZ's Avatar
Default Question about Comp 'R' Lifters
I purchased the Comp 'R' Lifters last year when I did me H/C install. I remember them going in with some work (a little bit of force). Yesterday I just took them out and encountered the same kind of resistance. Is this normal ? My experience has been that lifters usuaully fall into place without hardly any force. This is not the case with the Comp 'R's . So my question is this, did any of you guys that have these lifters experience the same thing ? If so how do you correct it ? BTW my stock lifters, which I dont have anymore <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> , fit perfectly. Thanks in advance.
John
<small>[ May 01, 2002, 08:54 AM: Message edited by: TRYMYZ ]</small>
Old May 1, 2002 | 09:01 AM
chasgiv3's Avatar
Default Re: Question about Comp 'R' Lifters
Mine did not require any force at all. Slid in very nicely. Not sure what the problem could be. I actually had a friend of mine who does VERY accurate measuring for the fabrication of injection molds measure the lifters. They were dead on. Course except for the plunger depth. The diameter and external shape was the same. I've had mine in since 1999 when I did the heads and cam.
I believe I still have the stock lifters. I'll see if I can find a R lifter to measure it again.
By the way I know I've heard of block distortion cuasing lifter issues from GM. But I've never heard it on the board before. I really doubt that's the issue here.
Old May 1, 2002 | 02:01 PM
ChrisB's Avatar
Since the fit is so close if you are not pushing
virtually exactly on the same axis as the lifter bore you can experience resistence. Residue oil
can also cause resistance since the fit is so close.
chris
Old May 1, 2002 | 03:13 PM
TRYMYZ's Avatar
Thanks for the info so far. It appears that they should fit just like stock. Well they dont seem to. Maybe I just got a bad batch. We will see.
John
Old May 1, 2002 | 10:35 PM
Batmobile/SS's Avatar
I used "Crane" lifters during my H/C swap and noticed the same thing. The Cranes took a little effort to get them in while the "Stock" ones did not. I have noticeable valvetrain noise and have wondered if the lifters are contributing to it.
Old May 2, 2002 | 01:26 AM
Kevin's Avatar
Whats the part number for the Crane lifters?
Kevin
Old May 2, 2002 | 07:03 AM
TRYMYZ's Avatar
That sounds exactly like what I am getting. Hmmmm. Is this normal ???
Old May 2, 2002 | 09:20 AM
BurnOut's Avatar
Where can I find a set of these lifters?? Do I need to order them direct from Comp, or...?? I have checked with most of the sponsors/online speed shops and haven't found anything. I also can't find anything about them on Comp's site.
Also, @ what should I expect to pay?? Thanks.
Old May 2, 2002 | 09:40 AM
Raughammer's Avatar
D(irecto)r Pepper
If the lifter bore is clean they sould go right in.
They should be have to be turned just so to go in smoothly, but they should go in with ZERO "force".
Once they were in did they move up and down smoothly? Were you able to turn the cam over with little effort when the push rods had not been installed yet on top of the lifters?
Good luck.
Old May 2, 2002 | 10:36 AM
TimZ28's Avatar
The set I installed in my last engine had one lifter (Type R) that was not completely round. You could see the distortion of the lifter body. It wouldn't even begin to go in. I had to have another one overnighted.
Old May 2, 2002 | 11:00 AM
Crane Part # 10530-16 OE design.
Old May 2, 2002 | 11:32 AM
TRYMYZ's Avatar
They did infact move up and down, but I am sure they were rubbing. I can see a little scuffing on the lifters. They definitely dont go in with ZERO force. Thats what worries me. I guess Morgan Motorsports will check them out and replace if need be. From what I gather, there is something not right with those lifters. Thanks for the info.
John
Old May 2, 2002 | 04:26 PM
Kevin's Avatar
Thanks Batmobile
Good luck getting a set of Comp lifters right now. Ive been trying my hardest to get some but apparently they are on national back order for a few weeks. Guess Im getting the Cranes.
Kevin
