ARE Valves: Replace 941 Springs with K-750s?
1. Are the K-750s made of the same materials as the 918? Same spring pressures?
2. Are there any issues with the K-750s handling high revs?
3. Has anyone swapped the 941s for the K-750s?
4. Has anyone broken a K-750?
Other people have had good luck with the 750's but I don't trust them. Just my .02.
Pressures are also different:
941: Seat pressure: 135 lbs. at 1.750 in.
Open pressure: 359 lbs. at 1.250 in.
K-750: Seat pressure: 130 lbs. at 1.700 in.
Open pressure: 380 lbs. at 1.150 in.
well we have an ARE car here with 750s with a broken spring...we are yanking the heads and installing doubles <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> (stupid 11/32 valves)
Comp Cams:
http://www.herbertperformance.com/Ca...e_springs.html
K-Motion:
<small>[ May 03, 2002, 11:33 AM: Message edited by: Jackyl_30 ]</small>
<strong>where do you see that they are H-11? Summit Racing is listing it (941) as steel. If fact both Summit Racing and Doug Herbert Performance classify it as a pacaloy (what ever that is. some sort of alloy I am guessing) material.
Comp Cams:
http://www.herbertperformance.com/Catalog/Valve_Spr ings_Retainers__Locks/CompCams_Valve_Springs/compcams_valve_springs.html
K-Motion:
http://www.herbertperformance.com/Catalog/Valve_Spr ings_Retainers__Locks/K-Motion_Valve_Springs/k-motion_valve_springs.html</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ok...here's the deal...I tried a replacement spring Crane Cams 99846-16. This is listed as a H-11 spring on cranes site. Guess what...it broke EXACTLY how a 941 did on me in the past. H-11 is one of the common ways they are making high spring pressures with a single coil spring.
Call it what you want...but its an H-11 spring (the crane/comp springs were identical in appearence and properties)
I was going off the assumption that the K-750 was a better product, therefore being different than the 941 based upon this thread: https://ls1tech.com/ubb/cgi-bin/ulti...c;f=1;t=004757
Read what Nick says towards the bottom.
In any matter I have decide to go with Comp Cams 987 springs.
<strong>What is the comp 987 spring like? properties?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">double springs <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
The Manley spring is similar to the k-750 and 941 in material and specs.
