P0302 Solved, Broken Valvespring
Old May 1, 2002 | 08:42 PM
Grave Danger's Avatar
Default P0302 Solved, Broken Valvespring
As many suspected.
Thanks for the advice!
All is well..........NEW question, has anyone installed a Oil Temp gauge? Is there "easy" place to install the sensor? I'm guessing the pan will have to come down?
I've notice the water temp never gets over 183* at cruise on a warm day since I've been monitoring it, If I'm correct, the water will reach 180 before the oil. Well the day the code set, it was 39* the water temp was around 178 and maybe the springs never heated up? Also if I discover that the oil temp is not getting up there then obviously I will have to put the stock stat back in.
As always thanks! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 1, 2002 | 09:02 PM
Dope's Avatar
Default Re: P0302 Solved, Broken Valvespring
http://www.xse.com/leres/ss/gaugepod.html
Dope
Old May 1, 2002 | 09:52 PM
Thanks Dope, very nice! <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
