Valves hit pistons,help me figure out why.
Old Jan 29, 2007 | 02:36 PM
Old Geezer's Avatar
Default That, along with...
Originally Posted by speed_demon24
Just because springs are rated for so and so lift doesn't mean they have enough spring pressure to control the valves. And just because the cam doctors out fine doesn't mean the timing chain and the slot for they key in the crankshaft is machined perfect, degreeing the cam checks all of the tollerances.
Checking the piston to valve clearance...
Old Jan 29, 2007 | 03:07 PM
SPRAYED 01's Avatar
How do i check piston to valve clearance?
Old Jan 29, 2007 | 03:50 PM
heavymetals's Avatar
I have heard of using modelling clay and measuring the squish.
They put a ball of it on the valve and see how far it is compressed by the piston. PITA
Another way is with depth guages.
Many ways to skin a cat...
Old Jan 29, 2007 | 04:07 PM
SPRAYED 01's Avatar
Got to admit it sounds very strange that a tr224 cam would have ptv clearance issues
Especially that ive had it in for 7k and 100+track passes with no issues. Im starting to lean more towards the fact that at my last track outing i bounced off the limiter alot at about 6800rpm. I was under the impression an ls1 with dual valve springs could handle that.
Old Jan 29, 2007 | 04:30 PM
vettenuts's Avatar
Originally Posted by SPRAYED 01
They are crane dual springs rated at .650 lift max. I was only running .565lift. The only thing i can think of is this. When i installed the heads from texas speed they had different valve seals on them that i couldnt fit the dual springs over. So i had to swap over the valve seals off my stock heads on the new ones. The new ones also had shims under the springs. I didnt transfer the shims because i thought they were only for the springs that cam on the new heads that i wasnt going to use. So if the shim was supposed to be there i could have floated a valve.
Bingo. The as installed Crane seat pressure without shimming is approximately 122#. I can't figure out your actual installation was when you removed the valve seals, did you use the Crane seats? What was the exact setup?
Old Jan 29, 2007 | 04:39 PM
SPRAYED 01's Avatar
The exact setup was the kit from Thunderracing. which was the tr224 cam,dual crane springs,crane titanium retainers,new seals and tr pushrod stock length. Then 3k after i was running cam only i did the TSP Ported ls6 heads. New heads stock deck height just ported and polished with a 5 angle valve job. TSP said the shim was not needed becuase i put the dual cranes on.
Old Jan 29, 2007 | 08:39 PM
NHRAFORMULA00's Avatar
when you hit the rev limiter you floated the valves just enough to touch the pistons,thats why you only found one bent(STAINLESS ? ) i would pull the other head, check for marks,im guessing they are there. Check you heads on a bench by pouring gasoline into each chamber and see if it leaks past the valves.if it does you need to have them ground. also i would have the springs checked and see if they are close too spec.I would also degree the cam on installation,its the only way to be shure!
Old Jan 30, 2007 | 10:02 AM
PREDATOR-Z's Avatar
How do you get floating valves from hitting rev limiter on a A4??? This is not a mechanical over-rev.
When you hit the limiter your motor goes into a cut fuel/low timing mode. Granted not good on juice but not valve kissing area. I believe either the heads are decked (milled), or it is from the springs.
Old Jan 30, 2007 | 12:28 PM
Old Geezer's Avatar
Exclamation yep...
I agree....
Check the V2P. The CC site has the instructions, and Powerhouse has the tools.
Old Jan 30, 2007 | 03:32 PM
SPRAYED 01's Avatar
Im having the springs checked and the heads checked. I did a cylinder leakage test and a compression test on the pass side. There was no leakage and compression was about 205psi on all four. The valves are stock not stainless.
Old Jan 30, 2007 | 03:58 PM
LS1Formulation's Avatar
Another thing to ponder: When a valve job is done on a set of heads and the valve diameter is not increased, it sinks the face of the valve a bit more into the head. This in itself can cause the seat pressure to be reduced even on an identical spring setup. Pull a valve cover and measure your installed height. I still think it's reduced seat pressure that caused the problem.
Old Jan 30, 2007 | 04:21 PM
  #32
SPRAYED 01's Avatar
What is the proper installed height for an ls1. Im having the machine shop check that on the head that had the bent valves. Its already off.
Old Jan 30, 2007 | 04:40 PM
  #33
You need to find the proper installed height for the specific springs you have. They'll give you a seat pressure value at a certain installed height. The installed heights vary from spring to spring.
Old Jan 30, 2007 | 05:09 PM
  #34
vettenuts's Avatar
If you check your setup, you may find you are at aroud 120#, possibly less. Since the heads have been worked, you first need to figure out your unshimmed height, then you can compute the required height based on the installed seat force requirement. I would shoot for 135# - 140# and you also need to check compressed clearance between coils and compressed clearance to the valve seal. Don't just slap them in.
Old Jan 30, 2007 | 07:52 PM
  #35
RPM Mark's Avatar
That is a hell of a good point! A valve job will sink the face further into the seat and bring the entire valve up, causing an improper installed height and less seat pressure.
Can't wait to see what the machine shop measures the installed height at and the spring pressure...
Old Jan 30, 2007 | 08:41 PM
  #36
SPRAYED 01's Avatar
The heads have been worked over but not the valve seat. I spoke to texas speed and these are brand new 243 castings that they buy and port and polish them. They leave the seat stock. Crane said that at 1inch it should be 352. I just need to find out what the proper installed height would be and then wait for the results from the machine shop. I actually hope they are bad springs. At least i will have an answer to what caused this issue. Thanks for all the input, keep it coming and ill keep posted on machine shop results.
Old Jan 30, 2007 | 08:59 PM
  #37
SPRAYED 01's Avatar
Okay here is a thought. The crane springs are specifically designed for an ls1. So would it be safe to assume that they are meant to be used at stock ls1 height? Also, if i need about 140,can i tell the machine shop to shim to the height that would produce 140 provided that the springs are okay?
Old Jan 30, 2007 | 09:31 PM
  #38
RPM Mark's Avatar
Hey Al, if they did a valve job though, they machined the valve seat. Am I missing something??
Old Jan 30, 2007 | 10:03 PM
  #39
SPRAYED 01's Avatar
Yes they did machine the seat that is the valve job. Thats why the vavle sits higher.
Old Jan 30, 2007 | 10:21 PM
  #40
hammertime's Avatar
I can't see how a 224/224 cam could have PTV clearance problems with an unmilled head, even if it was not degreed. If it was that far off it would have to run very poorly.
Degreed or not, check the valve drop to see how they fare, and check the PTV clearance with a degree wheel, dial indicator and checking springs.
