Valves hit pistons,help me figure out why.
Cam sprocket, timing chain or crank sprocket. Check the alignment. You should have degreed the cam. As well as check TDC of the piston to valve clearance.
Get out of this valve spring idea. Also you can check valve seal with a air cukc and custom made sprak plug to air chuck to pressurize the head.
