are ls1 mains tty?
Old May 6, 2002 | 01:52 PM
cablebandit's Avatar
Default are ls1 mains tty?
Just talked with Barry at ARE and he told me I needed new main bolts since they were tty. I didnt think that they were..just the head and crank bolt/s. Can anyone confirm this? I only rev to the stock 6200 limit so if the bolts do need replacing, do i need ARP studs?
Old May 6, 2002 | 04:10 PM
Mike at Boost Performance.co.uk's Avatar
Default Re: are ls1 mains tty?
They may be right or not. Just because you use the torque setting followed by an angular setting does not mean you have a torque to yield fastener, merely that you are achieving a specific clamp load. LS1 tech manuals mention tty for the head bolts but there is no mention of tty for the main cap bolts. Mike.
Old May 6, 2002 | 06:18 PM
y2khawk's Avatar
I asked Chris at Katech about that when I dropped off my block for the machine work
They are NOT TTY
Old May 6, 2002 | 07:24 PM
so i can reuse the main bolts in my super hi revving 6200 rpm beast <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 6, 2002 | 08:19 PM
Riptide's Avatar
The main bolts are reuseable, but you may want to consider some better rod bolts. I didn't feel too good about the stock rod bolts after I felt them stretching, so I used Katech's rod bolts in mine.
Old May 7, 2002 | 02:32 AM
Kevin's Avatar
Yes they are reuseable but its not too much for some replacement stock ones.
Kevin
Old May 7, 2002 | 06:52 AM
I have ARP rod bolts...just wondering about the mains
Old May 7, 2002 | 02:59 PM
Put it this way. I will re-use my bolts as I've seen nothing to say otherwise. If yours look good you could think about doing the same. They aren't tty. Mike.
