Replace timing chain w/ H/C ?
Old May 8, 2002 | 04:28 PM
NastySSoo's Avatar
Default Replace timing chain w/ H/C ?
I have 46k on my M6. Should I replace my timing chain and gear with the H/C install. If so, stock or Cloyes? Please give any opinions on this.
Paul
Old May 8, 2002 | 04:31 PM
jmX's Avatar
jmX
Default Re: Replace timing chain w/ H/C ?
I'd get the Katech chain if I were you. Stock gears. Thats what I'll be doing.
This isnt something you absolutly have to do, but while you are in there you might as well. SLP sells a double roller chain too, but its install will be a little more in depth since you have to pull the lower chain gear off the crank and press a new one on.
Old May 8, 2002 | 04:51 PM
NastySSoo's Avatar
I dont need any unnecessary expences, but if its the right thing to do I will.
Paul
Old May 8, 2002 | 07:49 PM
Kevin's Avatar
Yes do it. I didnt when I did my heads/cam at 30k miles and know Im rebuilding due to a broken chain.
Kevin
Old May 8, 2002 | 08:20 PM
NastySSoo's Avatar
Thanks Kevin, anymore opinions?
Paul
Old May 9, 2002 | 09:12 PM
MyLS1Hauls's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Kevin:
<strong>Yes do it. I didnt when I did my heads/cam at 30k miles and know Im rebuilding due to a broken chain.
Kevin</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What size cam were you using? Springs? Just wondering what setups are contributing to this.
Brad
Old May 10, 2002 | 04:26 AM
AlonzoVersion 1.0's Avatar
Yes you really need to replace it.Any time you change cams.Consider it cheap insurance or you will end up like hte other guy.
Old May 10, 2002 | 10:09 AM
MNSS's Avatar
Id get the cloyes, you can adjust the timing in 1 degree incriments sp? Plus you can get rid of the flimsy stock unit! about a 150 bucks
Old May 10, 2002 | 11:36 AM
XtraCajunSS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MNSS:
<strong>Id get the cloyes, you can adjust the timing in 1 degree incriments sp? Plus you can get rid of the flimsy stock unit! about a 150 bucks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you get the Cloyes, don't use the chain it comes with. Get and IRL chain. It is a much better piece.
Shane
Old May 10, 2002 | 02:47 PM
Damian's Avatar
LSX Mechanic
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">What size cam were you using? Springs? Just wondering what setups are contributing to this.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I helped Kevin build his motor. He was running a T1 cam, and Comp 941 springs. The valvetrain had nothing to do with the chain snapping, his springs held up fine...
Josh
Old May 10, 2002 | 03:05 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I didn’t change mine. I’m not worried.
Old May 10, 2002 | 03:20 PM
NastySSoo's Avatar
Thanks for the input. I think I will replace it with another stock unit.Its held up to weekly trips to the track for many, many passes.
Thanks Paul
Old May 10, 2002 | 03:26 PM
BADZ's Avatar
Moderator
Just bought the cloyes IRL chain and its beefy as hell. The other chains look like a bicycle chain while this one looks more like a motorcycle chain. Don't get the replacement for the stock chain by cloyes, get this IRL chain and be safe with your investment!!!!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NastySS00:
<strong>I have 46k on my M6. Should I replace my timing chain and gear with the H/C install. If so, stock or Cloyes? Please give any opinions on this.
Paul</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old May 10, 2002 | 05:49 PM
MyLS1Hauls's Avatar
Kevin</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Were you using an aftermarket underdrive pulley? I've seen the Whisper unit break chains due to engine harmonics.
Brad
Old May 11, 2002 | 01:50 PM
BADZ's Avatar
Moderator
Texas Performance has them and they sell for 340.00 which is a bit steep but you can really tell a big difference!!!!
Old May 11, 2002 | 02:14 PM
Kevin's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MyLS1Hauls:
[QBWere you using an aftermarket underdrive pulley? I've seen the Whisper unit break chains due to engine harmonics.
Brad[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was/am running the ASP pulley. It has been on there for 2 years. I should mention I was running about 130mph when it snapped and at around 4500 rpm. I dont think anything in the setup contributed to the failure...simply 3 years of drag racing and driving it like its supposed to finally took its toll.
Kevin
Old May 12, 2002 | 12:50 AM
Amarillo2's Avatar
Where to buy the Cloyes/Irl and how much is it?
