Stroker kit
Old Jan 30, 2007 | 12:37 PM
Tiger2o69's Avatar
Default Stroker kit
I have 6.125 Rods and -9cc Mahle Pistons.. Im 99% sure I have a spun bearing.. If I decide to go back with a 4.00 inch crank can I use what I have already?
Will it change the compression?
If so what all do I need to change.
If not I will need:
Crank
New Rod and Crank bearings
New Rings?
Anything else?
Old Jan 30, 2007 | 12:40 PM
Stang's Bane's Avatar
Pistons are specific to stroke and rod length.
Tiger2o69's Avatar
Ok well I see I will need new -30cc pistions to keep my 9.5 compresson
Old Jan 30, 2007 | 02:42 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
or get bigger cc heads...
Old Jan 30, 2007 | 02:52 PM
Tiger2o69's Avatar
I would probably lose more money on swapping the heads. There cnc ported and hand ported by Bo for FI.. I would probably lose 2-3 hundred on them..
The Pistons have 1500 miles on them.. I assume I would lose about 100 or so on them..
Hmm wait.. If I didnt change pistons that would save machine show money also.. Ill have to figure out which is cheaper..
Old Jan 30, 2007 | 05:16 PM
slow trap's Avatar
you will be able to reuse your rods but if you don't have a 4" stroke crank to begin with your pistons will be way out of the deck.you still running the stock 3.622" stroke crank ?
Old Jan 30, 2007 | 06:02 PM
Tiger2o69's Avatar
Yeah I have the 3.633" right now.. I want to go to the 4" crank.. Cant you change the wrist pin place? Either way it would change my compression which is bad.
Old Jan 30, 2007 | 07:33 PM
ChevyChad's Avatar
That must have cost a fortune to get a custom 3.633 crank!!! (Stock is 3.622).
No, you can't change the wrist pin location on the piston. Are you effin serious? If you get a bigger stroke crank, you need new pistons.
You can change your compression with the piston dish and with head cc's.
Old Jan 30, 2007 | 08:03 PM
Tiger2o69's Avatar
Nah.. Had a friend do it pretty cheap. Most people say the small change isnt worth it but hey every little bit helps huh. lol
I didnt know anything about changing pin location either but a sponcer on here told me thats all I needed to do.
